Bike: Reign Zero with Hayes HFX-9 (Carbon, but that’s just the levers I think, no different to any other HFX-9)
There is a bad rubbing problem on the front. From what I can see, both pads are “out” a little further than they should be, with one side “out” way further than it should be. If I take out the front wheel and push them both back in, they either push back out or stay in until the brake is pulled, then push out and rub again. The rubbing is ok until I actually get on the bike and ride whereupon, I end up getting a terrible howling, especially on slower climbs where I’m probably putting a bit of extra flex on the forks.
Sounds to me like they need proper full blown bleeding. I’ve done this with the back, and TBH, while eventually successful, it was a bit of a pain in the arras.
I’m riding tomorrow and have neither the fluid or time this evening to properly bleed them. The howling will piss everybody off!
Any ideas? I’m thinking, undo the bleed nut, push them back in, redo the bleed nut and put up with having to pull them a little harder on the ride tomorrow.
Having said all this, I’ve had them over two years, with absolutely no problem at all apart from straightening out the disks every so often. They’ve been absolutely fault free.
Suggestions for a quick fix (LBS will be getting bike next week for a proper service) welcome. Thanks everybody.
