OK, on my trusty old Patriot I have Hayes HFX Nines front and rear.
For some reason the front one just won't (can't!) align properly.
I'm running an old Marzocchi Z150 fork so I have an adaptor for the brake. The wheel is a Hope Bulb hub.
Normally to align a Hayes brake I just loosen the bolts and clamp the brake on and re-tighten them – job done.
But if I do this the rotor still rubs! If I look at it carefully the inside piston is fully in (and it's this side that is binding).
It's almost as though the caliper is not far enough over towards the wheel – but it's adjusted as far as it can go.
OK, I could put some shims onto the adaptor to move it over a mm or so, but I'm just wondering why it doesn't want to align properly in the first place.
