Put those knackered pads back in for the journey home, then replace when you get back – as above you be tempted to use the brake on the way home and the pistons may pop out casuing you loads more hassle. Though it usually the case that if one pad is worn to nothing and the other isn’t, that the piston on the non-worn side is sticky or jammed, hense why it’s not pushing the pad out and getting worn as the same rate as the other side. You need to get it moving again, or the same will happen with the new pads, sometime just lubricating the piston, and pushing it back and forth is enough, other time a complete strip is required.
