Macs dont go wrong, ask Rudeboy
S’not the Mac, that’s gone wrong, but a component made by a third party manufacturer. 😉
Does sound like a graphics card problem/dodgy connection/fecked LCD Display display.
You can try running a separate monitor from it, and use the Mirrored Displays option in System preferences. If the problem is in the graphics card, it will manifest itself on the second monitor. if not, then probbly a dodgy connection/faulty LCD Display display.
Could possibly be a firmware issue, which might be solved with a Firmware update, but that would probbly show up straight after a Software Update*. I took an old G3 iMac from OS9 to OSX, without doing this, and had an almost black screen. A second monitor attached proved the update was successful, but the Firmware needed updating. Was perfect, after this had been done.
Macs are suprisingly fixable, provided you’re prepared to hunt around for the info. I’ve ‘fixed’ several Macs, simply by digging around on tinternet for information.
*The Mac would probbly tell you if a Firmware Update was needed.
