Gears and brakes checked lubricated & adjusted.
Chain and drivetrain checked for wear.
Chain lubricated.
Tyres checked for wear, damage and inflated to pressure.
Wheels checked for alignment.
Steering checked for safety and adjusted if required.
Bearings – checked for wear
Bottom Bracket (and crank) removed, greased and refitted.
Seat post removed, greased and refitted.
Bearings re-greased (Excluding Sealed Bearing Units)
Gear cables replaced.
Adjust gears F&R
Brake Bleed Front & Rear (Hydraulic brakes only)
Gear hanger checked and tracked.
Advice given on any future issues
To be fair, half of that is a load of old tosh and doesn’t need to be done/requires no skill. Actually, scrap that. Nothing on that list requires any skill, just some knowledge. If you pay for service, you are a chump. The knowledge is so readily available on the net these days there’s no excuse.
Gear hanger checked and tracked. LOL. Tracked indeed.
Actually, the longer I look at that list, the more BS I see and the angrier I get. Now I remember why I gave up with bikeshops and order online.
