Viewing 4 posts - 41 through 44 (of 44 total)
  • Guitarists – a question
  • molgrips
    if there isn’t then you aren’t very good!
    No arguments from me there 🙂
    eddiebaby
    If you reverse a classical guitar then the strings are the wrong way round, reverse them and it will sound rubbish as the top thicknessing and bracing are set up for different properties and tensions of the bass and treble strings.
    seosamh77
    The bridge and the nut are the only things you’d need to change on a classical. And that wouldnt cost much, few quid, plus they aren’t usually glued in so it’d be no hassle.
    chiefgrooveguru
    I was sceptical about this because lots of guitarists/bassists labour under the misconception that lower/heavier strings are higher tension when the reverse is usually the case. Anyway, it seems that classical guitars are usually symmetrically braced so ideal for reversing should you want to.
The topic ‘Guitarists – a question’ is closed to new replies.
