^^ fork damper oil doesn’t actually make a very good lubricant.
I’ve just striped, raked out (literally) and refilled a marzocchi doppio air cart. Over the years fork damping oil had gotten into it (and possibly some from factory/service) and caused the thing to jolt up and down, the O rings using the damper oil to stick to the inner walls of the unit like crazy. Post clean op, a few smears of Slide lube (usually for a lathe saddle etc) in there and now buttery buttery buttery smooth, the difference was incredible.
Have a few pairs of forks to build this week and I think Havoline slide lube will be finding its way into other parts of the fork*
*bush’s often have a teflon or ceramic coating on them that is quite porous and actually requires the right kind of fork damper oil/open bath oil to provide any form of lube; if you use the wrong oil the fork will feel slack and have all the smoothness of a washing machine been dragged through gravel (and it’ll likely wear through the stanchion or bush in a matter of hours).
