My front rotor has a 4-5 small grooves running all the way round it. I suspect from trapped grit in the pads.
Is it ok to have a few grooves in the rotors, will the bike blow up?
Seriously, should I ignore it, try sanding them down or replace?
The braking performance of the front is pretty poor, I upgraded from Tektros to XT (m765) and didn’t notice any improvement, this may a separate contamination issue though and I’m going to give the pads and rotors a good clean up(levers feel pretty firm so don’t think its a bleed problem).
Rotor is 180mm & I’m 15 stone
