After many years of extolling the virtues of paper maps I think it might be time to investigate GPS thingies. I will always route plan using paper first for offroad stuff, but for road stuff, especially longer distance, things like bikehike or even Google maps is easier.
So I’m not fussed about off road use for a GPS, but I would like the following:
1) Screen to show me how far to the next junction and which way I’ll be going with a little map. Like a sat-nav I suppose but doesn’t have to be as detailed I think if thats going to be uber expensive.
2) Waterproof – are they waterproof as standard?
3) Able to attach to handlebars
4) Can be charged with a USb type cable – I have a hub dynamo which should power/charge it if needed.
5) Easy to load a route to – can this be done via a phone or is it a PC job everytime? Don’t use my PC much nowadays.
I have an iPhone – can you use one as a GPS? I know you can as a sat nav but thats not the same as loading a route onto a device. Is there any apps that do this?
Thanks for the help!
