Well it was bound to happen.
The first worm to infect the Apple iPhone has been discovered spreading "in the wild" in Australia.
The self-propagating program changes the phone's wallpaper to a picture of 80s singer Rick Astley with the message "ikee is never going to give you up".
Source: bbc.co.uk
…anyways to negate the worm from working, follow these instructions:
Q: How to change the dedault password?
A: Simple, if you are on a Jailbroken iPhone, make sure that you immediately change your iPhone password from ‘alpine’ to something else. Here is how to change your iPhone password via OpenSSH with the following instructions:
Install MobileTerminal.app on your iPhone via Cydia.
Launch MobileTerminal.app. Type su then tap return.
You will be now asked to enter current password. Type alpine then tap return.
You can now change your password. Type passwd then tap return.
Type your new password. Type then tap return .
Retype new password. Retype then tap return.
Done! Your iPhone should be more safe now.
Source: phonenano.net & iphonebyimuggle.blogspot.com
