Second (or third or whatever) getting the proper Bonty rim strip. Got the strip and valves from Pedal On and it was a doddle. Bonty tyres, rim and rimstrip all goes up with a mini pump if needed.
Only tip, I got a perfect seal first time, every time with Jones XR's and Big Earl wets if I had both tyre beads in the middle, if I only popped one bead off the rim, say to add sealant it needed more vigorous pumping but with both beads in the middle it really did go up like an innertube,
I was both astounded and very pleased. 🙂
EDIT- got hold of a syringe to add latex through the valve with the core removed and it is now even easier to set up, waiting on a new rear tyre (thanks Vinneyc) and know it will be a quick, clean job.
Put tyre on
Pump up tyre with a bit of water, soapy if I am near the kitchen.
Remove valve core
Add sealant
Pump up
Quick shake then ride.
