I’m pretty sure most Japanese bikes were designed to run on boggo unleaded from the mid-late 70s.
If your car or bike can take advantage of the higher octane fuel whether it’s through fancy-dan electrickery, or accidentally having made the compression ratio too high or the timing too advanced to be able to use the cheap stuff without it blowing up then there’ll be a performance advantage. If not, there won’t, and it’ll be slower because the higher octane fuel doesn’t burn as quickly, therefore the expansion of the gases happens at the wrong time in the piston stroke (or rotor for all you Wankels!) to get the most out of it.
So probably no, but possibly yes 😀
Super unleaded and Avgas smell a bit nicer too.
