Only added a dropper to mine, and that was after it was a year old.
I have a set of XT brakes on another bike and I did think about swapping them over, but the bottom of the range shimano jobbies are easily as good so haven’t bothered.
Depending on your weight will determine if the rear shock needs tuning for you. Any thing over 80kgs will need it to stop the shock blowing its travel.
I had mine done by mojo and it feels loads better.
Stock saddle is a bit flat so I changed to my regular charge spoon.
I changed my forks, nothing wrong with the stock fox but I upgraded to a set of 150mm revelations to raise the front up a bit.
Standard bars etc are fine to be honest but it’s a personal thing I guess. One thing that is good about the 2015Trance is that they have gone back to normal tapered forks rather than giants own overdrive system.
It’s well documented on here that I’ve struggled to get used to the new geometry of this bike but I think I’m finally getting there. ……
I’m adding a giant dropper post to it later this week.
Not sure if the wheels are tubeless ready to be honest.
I have a SX, changed the rear shock to a DB Inline (200×57) so slightly more rear travel. It’s 1×10 with a Zee rear mech and NW chainring. Swapped the brakes over to a set of SLX ones I had and a Madison Flux saddle. Bars/grips changed to 750mm/thicker grips. Tyres are now Purg rear and Minion front both tubeless. Have a FIT cart to go into the fork too. Still to decide if it’s a keeper…
I have a 26inc wheel model, with Sram x5 gearing, 120mm epicon air forks, mavic cross rides, charge spoon on a joplin dropper (ks in post) 760 wide nukepfoof bars on a 50mm stem and deore brakes, bike is a small, only just put it together and ridden round Gisburn once and felt comfy. Anything anyone would change?
Heavy duty spacer & polymer eyelet bush in the top mount of the shock as they tend to wear fairly quickly, worked well with the team bikes from a few years ago with maestro systems.
I have an older 26″ Trance but the Maestro suspension platform is essentially unchanged – I’d agree with Renton about shock tuning if you’re a porker like me – mine is in dire need of a tune – to prop it up when climbing it needs loads of air in, but it’s then not soft enough to be working properly downhill. It’s as if the ProPedal needs to be made more ‘intrusive’ at lower pressure. Will be off to TFT for a PUSH when I’ve got some spare cash.
Has anyone done this, out of interest?
I believe giant dropped the lower linkage placement by around 9mm on the newer trance which apparently has made the rear end a lot more active and more susceptible to bobbing around.
I built up an Advanced SX frame with an XO1 groupset, Pike 150s, Flow EXs on Pro2 Evos, Lev Integra dropper, XT brakes, SDG Belair 2 saddle and Easton Haven 740mm carbon bars. It’s a great bike that goes up and down well and will be getting its first trip to the a Alps on Thursday to play in the snow with some Ice Spiker tyres. Can’t wait!
LoCo – Member
Latest Trance has bearings on the top shock mount (same with bottom mount). Rear end is very plush, I bought mine frame only, so came with a monarch RT3.
Very impressed with the bike, value for money on the full builds is good as well, frame is light, mine is at 29lbs with EXO tyres.
I’ve had a Trance 2 for about three months now and it is beginning to come into it’s own as the suspension units bed in.
The things I have changed so far:
– Tyres changed to HR IIs straightaway.
– Handbars changed to Easton Havens purely because I had some lying around.
– Grips changed to Superstar as I prefer them.
– Seatpost changed to a dropper.
– Saddle changed out of personal preference.
TBH it’s an excellent bike out-of-the-box but I would seriously budget in a new set of tyres. Everything else is down to pure preference.
The suspension units are pretty basic and, in the long-term, will probably be swapped out, but I’m in no hurry as they do the job.
I got a trance 3 a few weeks ago ( 2014 ) couldn’t get the standard plastic nobby nics to go up tubeless so I got some s.s.tactic wheels and purgatory front, ground control rear. This saved a ton of weight. Also converted to 1×10. Standard rock shox suspension is pretty good. Just under 30lb with dropper post. Anyone want to buy a nukeproof mega?
I’ve been on a Trance I bought new and much upgraded since 2008. Maestro is superb. Which is one reason why I’m sticking with Giant and speccing it how I want.
Mine’s a 2014 Trance 2, so some of my points may not be valid/required.
Fox 32’s were awful and got replaced with a set of 160mm Pikes and a 50mm stem (as I also get rid of OD2 in the process).
The rear fox ctd shock is simply rubbish (probably made worse by me not being the lightest).
The wheelset is lasting well, though you do need to keep a close eye on you spokes as they do seem to get loose quite easy.
Only had to remove play from the Hub’s once so quite impressed there.
Brakes were ‘ok’, but I’ve replaced mine with SLX’s and also changed the discs to 203mm in the front and 180mm on the rear.
Overall it’s a really good bike/frame and some choice upgrades really enhance it.
re the Overdrive stuff, I posted yesterday about this in relation to my 2015 Anthem SX. It has a normal tapered steerer on the Fox 32 CTD fork, a slightly oversized stem with a shim, and it says ‘Overdrive’ on the headtube. So normal fork, and a normal stem would fit in place of the shimmed Giant one.
