Getting felt tip pe...
[Closed] Getting felt tip pen off painted walls?
[#5185933]
Any ideas?
Spray cleaner doesn't work.
Not tried WD40 yet!
Posted : 24/05/2013 1:08 pm
Repaint the wall & keep the tub for when it happens again!
Posted : 24/05/2013 1:09 pm
bleach spray?
try some other solvents
acetone/nail polish remover
paraffin
hit fairly firmly with a stick or belt
- won't clean the wall but might prevent a repeat 😉
Posted : 24/05/2013 1:12 pm
Washable pens FTW
White spirit usually works, but you will take some of the paint off with it.
Posted : 24/05/2013 1:17 pm
You could try IPA, but it will probably take most of it off, but leave a faint smear.
Although, emulsion or gloss?? Emulsion will probably end up in a smeary mess.
Posted : 24/05/2013 1:18 pm
Baby wipes, worked for us. Probably depends on paint & ink.
Good luck!
Posted : 24/05/2013 1:19 pm
Give them more pens, let them have more fun, then repaint
take the opportunity 🙂
Posted : 24/05/2013 1:20 pm
^ good point, baby wipes are amazing. Lord knows what's in them, but they seem like a universal solvent 🙂
Posted : 24/05/2013 1:21 pm
lightly sand the wall 😉
worked for me on ANY dirty mark in rentals.
baby wipes are ace for cleaning chains 😉
Posted : 24/05/2013 1:22 pm
dampened felt cap on childs head
Posted : 24/05/2013 1:32 pm
Washable pens FTW
I read that with an 'i' in it and wondered how that might help the OP......
Posted : 24/05/2013 1:57 pm
 ski
If all the above fail, try nail varnish remover, lost count the number of bits now I have cleared up with it.
Posted : 24/05/2013 2:14 pm
weird, I was just watching this before checking STW
[img] http://www.debutart.com//media/16398/small [/img]
video here:
http://www.debutart.com/motion/jon-burgerman/aol-nyc-mural#/motion-portfolio
Posted : 24/05/2013 2:17 pm
I like that.
Buckle end?
Posted : 24/05/2013 2:20 pm
Go over it with a whiteboard marker. The solvent that makes it non-permanent should lift it.
's what you do when people use permanent markers on whiteboards anyway. With kids' pens and a porous surface it might not be as effective. I'd probably have a punt though.
Posted : 24/05/2013 2:26 pm
try using a spray deodorant something like lynx works great with permanent marker so should work
Posted : 24/05/2013 2:50 pm
Try an eraser. It is a bit like sanding but less aggressive. Worked from me in rentals when there were tyre marks hall wall.
Posted : 24/05/2013 3:27 pm
Use some of your handy 5L tin of paint thinners. Doesn't everyone have one?
Either that or maybe brake/carb/glasses cleaner
It will however stink the house out and make everyone mildly high.
Posted : 24/05/2013 6:16 pm
