Interesting but somewhat mis-leading web page 😆
He talks about vibration loosening fasteners – he’s right it does. But he doesn’t explain why it loosens fasteners. The reason that vibration loosens fasteners is because it momentarily overcomes the tension in the joint and allows the nut/bolt to slip relative to each other and the clamped components.
Best mechanism to ensure joints don’t loosen; a properly designed joint. A large enough bolt/nut/thread/interface to support a large enough tension that resists all the loads. Then tighten the joint to the correct torque value.
All of the anti-rattle devices in the world (Nyloc nut/thread-locking compound etc….) won’t work if the loads, including the vibration loading, exceed the tension in the fixings and joint.
