what i do like about this forum is the complete and utter bulls poo that some posters put up as though its gospel. a combi can go in any room.. restrictions are in place for most bathrooms re positioning eg not over the bath mostly but each boiler has specific manufacturers instructions that mustbe followed.
i d say its a pretty even split bare on the wall and in a cupboard or wardrobe. old airing cupboard probably the most popular bedroom site. again a combi in a cupbaord or enclosed space has ventilation requirements the manufacturers instructions will clearly detail these though rather than physical vents in doors the requirement will be arounds space at the sides and at the front and above and below the appliance
combis always use the flue for air ( usually the outer of the two tubes in the flue) and combustion products in the inner tube. the couter cover often provides an airseal around the inner compartment should there be an escape of products of combustion/gas.
unless you are a competant person as defined by the local authority you have no business advising anyone on the need for gaps under the floor for air or gas. advice on installing an audible co alarm correctly installed can save a life (as one of mine did just this weekend)
unless someone can quote me a BS reference i ve a strong belief that it is not compulsory to fit a co sensor in any room where a boiler is installed nor is it compulsory to fit fire alarms nor link them to such alarms..
