Hi,
I wonder if anyone can cast an eye over the following 2 quotes to see if they are reasonable as they seem pretty pricey to me! (I will be getting more quotes but this affects the budget elsewhere).
There are 2 options. First is to replace a conventional boiler with a combi, second is replace the conventional for a new one and relocate the immersion tank to the loft.
1. £3,234.76
To drain down and remove the existing boiler and flue.
To make good the flue hole.
To drain down and remove the old hot water cylinder, cold feed tanks
and redundant pipework.
To supply and fit a new Worcester Greenstar 34CDi Classic condensing
combination boiler with a standard flue, magnetic system filter and
comfort2 programmable room thermostat.
To run a new gas supply around the rear of the property at low level to
the boiler location.
To run a new condensate pipe to drain.
To connect the new boiler to the existing hot, cold and central heating
pipework.
To fill, test, commission and add inhibitor on completion.
2. £4,795.69
To drain down and remove the existing hot water cylinder, cold feed
tanks and redundant pipework.
To supply and fit a new Worcester Greenstar 18Ri condensing regular
boiler with a standard flue, magnetic system filter, wiring centre and
To supply and fit on a reinforced base into the loft a new 210litre
unvented hot water cylinder with all assocciated pipework, fittings and
controls.
To run a new blow off to drain.
To connect the new boiler to the existing central heating system.
To connect the new boiler to the new hot water cylinder.
To connect the new cylinder to the existing rising main and hot water
system.
Thanks,
