just5minutes – Member
Slightly off topic but has anyone had a problem syncing maps / routes from their garmin connect to their device?
I’ve tried a number of times from a mac and PC and have had no success with either – hitting the “send to device” button just fires up Garmin Express which then doesn’t do anything, and the option to sync the device is greyed out even though it’s connected by USB…
I’ve found a workaround that eventually works after a number of attempts whereby I use the Garmin iPhone client to sync the route to my phone and then from the phone to the device… it’s a bit of a faff though.
I’m quite new to Garmin but the device and PC software seems pretty poor – my ride yesterday was punctuated with two things that drove me nuts:
1. Travelling along a route I’d specified in advance it repeatedly told me to do a U turn / turn off onto the dirt track despite the fact I was on the course going in the right direction.
2. The edge device randomly beeped every minute or so even though this didn’t seem to correspond with the calorie, distance or altitude thresholds.
I’ve given up with Garmin Connect for sending routes to my device. I used gpsies.com.
If I use Garmin Connect, then the route will randomly appear and disappear from the screen as I go, which is annoying if it’s a route i haven’t taken before, or are not particularly familiar with. It works 100% fine so far with gpsies.com. This is with an Edge 500 and the issue is fairly well documented online; I think it stems from a firmware update, which royally messed things up.
My Edge 500 also randomly beeps at me, but this is normally the ‘off course’ chirp, when I am indeed on the course. It randomly loses the course, then finds it again a fwe seconds later.
