Garmin 520 mapping
[Closed] Garmin 520 mapping
[#7296386]
Garmin have just released the new Garmin 520 GPS ( https://buy.garmin.com/en-GB/GB/sports-recreation/cycling/edge-520/prod166370.html ) and I thought it might be helpful to other STW’s to post some of my findings regarding mapping on this unit (via web research piecing together how-to’s and the best options I could find).
First thing to note is that the Garmin 520 won’t search and plan a route for you by finding the best route along roads like a car SatNav would and like the Garmin 810/1000 will. If you are a roady and specifically want road navigation the 810/1000 are probably better choices for you.
However, as a Mountain Biker I don’t need that functionality, as I typically want to load a prewritten course (eg a .GPX file) and then follow that off-road course on the GPS screen. You don’t absolutely need a map on screen, to be able to follow a GPS course in this way. But it makes for far easier navigation if you can see your GPX course superimposed on a decent map, which gives some context to your route…this is where this post comes into play.
The Garmin 520 doesn’t have a micro-SD card slot for storing map data like the 800/810/1000 units, which at first glance may make it seem a bit of a non-starter for the 520 displaying decent maps or sensible map coverage. However it does have some internal memory, which can be used to store map data and it does have a good colour display screen.
By removing the standard (and totally useless) world basemap from the 520, this then frees up approx. 110MB of internal memory space, which can be used to store a far better and more useful map of a smaller area.
I’ve always liked OS Discoverer maps, but the GPS versions are very expensive, large in terms of file size and also they tend to look blurry as you zoom in. A better choice I found was to use a map from http://talkytoaster.co.uk which gives a similar look and feel to a OS map, complete with contour lines and features, but at a fraction of the size and cost, as well as being raster-based, so very clear when zooming in. This site provides some free UK mapping, but I recommend paying £20 for the subscription service, which gives really nice maps that are up to date and look great.
Now you can’t just load the whole UK mapping on a 520 due to the 110MB memory limit, but I found I could easily load a Talkytoaster map of the whole of North of England, from the Scottish borders south-wards, including the Peak district and that would use about 85MB memory (you also need to leave some room for other garmin route/activity/segment files, so best limit the map data to around 90MB). For my MTB purposes that is a big enough map area for me and since I can swap the map file out for another area (say the whole of Scotland) in circa 10 minutes with my computer, this isn’t really a limitation.
How do you do this?
Step 1 – Once you have a 520, buy and download the map you need from Talkytoaster.co.uk onto your PC or Mac (make sure you get the Basecamp version of the map, for PC or for Mac depending on what type of computer you are using).
Step 2 - Download and install Garmin Basecamp for PC or Mac. This will load several programs onto your computer.
Step 3 - Double click on the map file you downloaded in step 1 and it will run the Garmin Mapmanager program and install the map file you downloaded from talkytoaster onto your computer.
Step 4 – Now plug your 520 into the USB port on your computer and using file explorer or finder, look at the GARMIN folder on the 520. You will see a file called gmapbmap.img this is the (useless) basemap that comes as standard with the 520. Copy this file and make a backup of it on your computer for future safekeeping and then delete it from the 520. This will now give you approx. 110MB free memory.
Step 5 – Make sure your 520 is still plugged in to your computer and and then run the Garmin Mapinstall program. Select the talkytoaster map in the mapinstall pulldown menu on the first page and click continue. On the next page you will see the various map tiles that the overall UK map is made up from. If you can’t see them fully, use the zoom in control until you can. Select the map tiles that represent the map area that you want to have on your 520, bearing in mind that you want to select no more than approx. 90MB of mapping (helpfully it shows the amount of map data you are selecting at the bottom of the screen). When you have finished choosing the map tiles you want select ‘send maps’ then ‘continue’ on the next page and the program will then install a file onto your Garmin. This may take some time, be patient.
Step 5 – use windows explorer or finder to look at the GARMIN folder on your 520 again. You will now see a new file called gmapsupp.img we now need to rename that file to gmapbmap.img
Step 6 – Disconnect your 520 from your computer, turn the 520 off and back on again and you should now have good quality UK mapping!
Example screenshot of 520 with talky toaster UK map (the purple line is a course I had loaded)
[URL= http://img.photobucket.com/albums/v144/pockman/601.pn g" target="_blank">http://img.photobucket.com/albums/v144/pockman/601.pn g"/> [/IMG][/URL]
Enjoy!
Posted : 28/08/2015 5:58 pm
Cheers mate, very useful info there as I've just ordered the 520.
Posted : 28/08/2015 6:22 pm
How do the Talkytoaster maps compare to the OSM ones?
Posted : 28/08/2015 7:02 pm
My understanding is that they are based on OSM maps, but have added data to make the more detailed and more akin to 1:50000 OS mapping
Posted : 28/08/2015 7:39 pm
 golo
Useful info, thank you.
Is it possible to move the map around the screen to look around an area?
Posted : 29/08/2015 11:50 pm
I don't think so. I think you can only zoom in/out of your present location.
Posted : 30/08/2015 8:38 am
 golo
That seemed the likely answer - thank you for confirming!
Posted : 30/08/2015 12:20 pm
:mrgreen:
Posted : 16/09/2015 12:36 pm
Bookmarking & Thanks.
Posted : 16/09/2015 12:41 pm
Tried to install the Map earlier today however when opening the Garmind Map install program I get a message saying
"Some devices were found; However none have the necessary capabilties...
...You may need to set the interface option to 'Garmin or 'Host'."
Not found a way around it yet. Anyone else had the same issue?
Posted : 18/09/2015 3:12 pm
Try this one [url= http://www.dcrainmaker.com/2013/05/download-garmin-705800810.html ]Dc rainmaker version[/url]
Worked for me
Posted : 19/09/2015 11:12 pm
I get stuck here. Can do the free dcrainmaker version but trying to load up the talkytoaster maps gets stuck here. I can see them in Basecamp but it doesn't recognise my 520. thats using the garmin cable as well.
Posted : 21/09/2015 8:32 pm
Can you try another PC or Mac (could it be a USB port issue?)
Posted : 21/09/2015 9:51 pm
Does your 520 install as a mass storage device and/or a com port? Mine only installs a storage device which could be why it can't be found by mapinstall.
I'll try it on another PC tomorrow.
Posted : 21/09/2015 10:30 pm
Just sent you an email - suggest you try this.
As a workaround - You can use a USB stick to save the map onto from the mapinstall program, instead of trying to put it directly onto the 520.
To do this get a USB stick and create a folder on it called GARMIN. Plug this USB stick into your PC, leaving the 520 disconnected.
Then open up the mapinstall program and select the map area you require and then load the map onto the USB stick.
Next manually copy the map file off the USB stick onto the GARMIN folder on the 520.
Rename the file as per original thread above and turn 520 off and back on and all should be ok.
Hope this helps
Posted : 21/09/2015 10:50 pm
loading onto a USB key and then transferring across has worked. Thanks.
Posted : 21/09/2015 10:58 pm
Bingo! Good news 🙂
Posted : 21/09/2015 10:59 pm
Sorted. Missed a couple of tiles first time round. ~50mb to cover most of the SW.
Posted : 21/09/2015 11:34 pm
Worked for me also, downloaded the map tiles from openstreetmap and dropped the file into the garmin folder and changed the file name and it worked.
Shame the 520 still has has problems but I'm hoping the next update will sort that out 😐
Posted : 22/09/2015 9:38 am
I'm stuck.
Have the shiny new 520. Have the maps from TalkyToaster (the British Isles Contours NON Routable TT50 GMAPSUPP map). I've downloaded it, extracted it from the .zip and it is a .img file, 618MB.
I've also installed BaseCamp - which recognises the 520.
And then at step 3 - getting the map file to BaseCamp... nothing happens. No obvious way of loading, importing, drag and dropping the .img file into BaseCamp. It just doesn't want to know
On Mac OS X.
Ideas?
Posted : 29/09/2015 7:09 pm
Your file size is 618mb ??? the 520 only holds 100mb max and that is if you also delete the original basemap
Posted : 29/09/2015 7:37 pm
Beano68 - the file downloaded from TalkyToaster is 618MB. So I was expecting to be able to load it into BaseCamp and then select the areas I want.
Posted : 29/09/2015 7:44 pm
You don't want that file. You want the base camp version a bit further down the list. Then you can select which areas to load. Most of the SW is about 50MB
Posted : 29/09/2015 10:24 pm
Got it! MapInstall didn't work on either the Mac or Windows PC with the Garmin device. Turns out the USB trick works a treat and I now have the TT maps installed on the 520.
Added bonus, when browsing the Garmin folder on the 520 I found a file: "startup.txt" You can edit this directly on the device. Open it and edit away - to add a delay to the start up screen, I put in 5 secs, and then add your name and e.g. phone number or house number/post code. Could be useful one day should it go missing...
<!-- Edit this file to display a message while your unit is powering on -->
<!-- Allow one full power cycle after editing for your message to be updated -->
<!-- Set the display number to the minimum number of seconds your message is displayed -->
<display = 5>
<!-- Type your message on the next line -->
Ronnie Pickering
+441234567890
Posted : 03/10/2015 11:01 am
 J-R
Like AndrewBF I am stumped at Step 3 - Double click on the map file you downloaded in step 1 and it will run the Garmin Mapmanager program and install the map file you downloaded from talkytoaster onto your computer.
I looked at jam bo's comment, but the only obvious file "lower down" for PCs is: "Mapsets For Use With PC ONLY (MapSource or BaseCamp)" This downloads a 558MB zip file full of img files.
Talkytoaster's website provides absolutely no suggestions at this stage.
Can anybody who has done this help? I am using Windows 7.
Posted : 04/10/2015 8:31 pm
Download that one. Import it into base camp, export the tiles you want from base camp using map manager. This is the step that I couldn't do directly onto my 520 but could do it onto a USB key with a garmin folder and then copy it across.
Posted : 04/10/2015 8:56 pm
 J-R
jam bo - thanks for the reply.
How do I import it?
If I use the Basecamp option: File/Import into my collection, it only seems to recognise a limited range of file types, such as fit, gdb, gpx . . . but not img or zip.
Posted : 04/10/2015 9:19 pm
I think I unzipped it into a folder and then imported from there.
Posted : 04/10/2015 9:29 pm
Reading this post with interest as I'm pondering getting a 520. Makes me think, why on earth is it this complicated?! Why can't you buy something, turn it on and start riding?! This reminds me of a module called remote sensing I did 10 years ago at university and I was rubbish at it.
Posted : 20/01/2016 8:40 pm
Brilliant thread.....big thanks to skydragon
Posted : 20/01/2016 8:54 pm
You can. But the built in garmin map is rubbish.
Posted : 20/01/2016 9:03 pm
Thinking of getting a 520 but just got a few map questions. ....
Does the 520 do routable maps?
Do the newer OS 1:50k look maps on the talkytoaster website work on the 520, or do I have to stick with the older ones?
Posted : 04/03/2016 8:46 am
Picking one up from Halfords today, tick!
Posted : 04/03/2016 10:08 am
Yes it does but if that's your main use for the GPS then i would consider the 810 or 1000
Posted : 04/03/2016 10:11 am
I use the open street mapping @meeeee... You can get about 50mb of fairly detailed mapping for a reasonable area with that.
Its not routable but I've had no problems ever following a route if you zoom out to 200m
Posted : 04/03/2016 10:12 am
Hello. This may be a daft question. I have followed the steps above but when i load the map it does not look like the above. I have a blue background, not sure how to upload pics as this is first time i have posted. Thanks for the great thread btw.
Posted : 14/03/2016 12:47 pm
Do the open street maps or talky toaster ones have contours on? Could anyone post a screen shot of maps they use?
Thanks
Posted : 25/03/2016 12:24 pm
I also have this error:
Some devices were found; However none have the necessary capabilties... You may need to set the interface option to 'Garmin or 'Host'.
The suggested workaround doesn't work either:
In fact, when I run MapInstall the first thing the program asks me is to select the device where I'll install maps. My only option is to click on the find device button, and I get the above message. It seems I can't go to the next screen unless I select a valid device. And my Edge 520 isn't recognised as a valid one!
The weird thing is that BaseCamp sees my device. When I run BaseCamp, my Edge 520 is listed on the left pane, and it also shows the unit ID. It also shows my activities on the map.
My BaseCamp version is 4.6.2. The software on my Edge 520 is up to date. I can't find a way to avoid this issue. I looked for some sort of interface option on the device, but couldn't find any.
Posted : 24/06/2016 5:29 pm
I've solved with a script that takes advantage of mkgmap.jar...
Posted : 26/06/2016 2:17 pm
For future reference, here's what I did.
I used MapSource to identify the few *.img files I wanted to merge (6*.img files have the OSM data, 7*.img have contour lines data), and put those selected files in an empty folder. I also copied clas*.TYP file in that folder. For making things easy, I also copied mkgmap.jar there. Finally I run:
java -Xmx3000M -jar mkgmap.jar --family-id=6367 --family-name=openmtbmap --gmapsupp [67]*.img clas*.TYP
The argument of family-id is a 4-digit number. You take that id from the first 4 digits of the filenames of the 6*.img files you're merging.
Posted : 26/06/2016 7:37 pm
A simpler way is offered by [url= http://www.qlandkarte.org/ ]Qlandkarte GT[/url]. It works like MapSource.
From the Main panel select the Map entry. Then click on entry Select Sub Map, and select with the mouse the area you're interested in. Needed tiles will be automatically selected and shown. In the Selected Map panel you'll have info about number of tiles selected and size. Select that entry and click on button Export Map. Choose an output path and confirm with Export. When it finishes you can manually transfer the output file to the Garmin device via USB.
Posted : 28/06/2016 4:36 pm
this thread is VERY relevant to my interests... 8)
Posted : 01/11/2016 12:12 am
I wouldnt follow the instruction on here, theyre making an easy job very complicated.
Just google openstreetmaps for garmin 520.
Posted : 01/11/2016 6:24 am
