garmin 405 and memo...
[Closed] garmin 405 and memory map
[#1113088]
Does anyone know how to view routes from the garmin forerunr 405 on memory map?
I can view routes on google earth easy enough, but can't seem to get them to work with memory map (I do have memory map). Any help sppreciated.
Posted : 08/12/2009 8:01 pm
the only thing i can think of is if you go to gps on the top right of your options and click on import from gps thats all i do with my 305 😀
Posted : 08/12/2009 8:35 pm
um... you should be able to export them to tcx (or similar) format routes, then import them to memory map?
Failing that, plug into Garmin Connect and view them on Google maps?
Posted : 08/12/2009 8:47 pm
I have a Forerunner 305, but I think the same steps apply...
Plug your 405 into the USB cradle
Turn it on
Start Memory Map
In Memory Map select the top menu option "GPS"
Select "GPS Setup" from the list of options
Set Manufacturer to "Garmin", model to "USB"
Click "OK"
Select the top menu option "GPS" again
Select "Import from GPS" from the list of options
Select what you want to import (probably tracks, but do it all)
All items should now get loaded into memory map.
As an alternative I use GPS Babel to download single tracks, routes, etc, from the garmin device, but using abel is a little bit more complicated, although there is a GUI for it now.
Hopefully that should get you started.
If your using your 405 for training it's worth downloading and getting to grips with SportTracks by Zone Five Software, you can import all your training data and compare it mile-by-mile, day-by-day, etc, etc,, really useful, especially is you use a HRM with your 405.
Posted : 08/12/2009 10:13 pm
