Hi,
You would think the best source of info would be the local planning dept. but I was wrong! Basically looking to widen my garage to one side which is located at the end of my garden well away from the house and accessed from a shared private drive. It’s currently single storey flat roofed and just shy of a double garage so I intend widening it by a couple of metres. This will entail knocking a side wall down and sticking an I beam in on piers then spanning new and existing roof timbers off the beam to each side wall. I will keep the construction 200mm off the boundary wall. Now I just need to find out if I require p permission and or building regs? Anyone had experience with similar? Don’t know if this makes a difference but I will be removing the asbestos flat roof and replacing with some other form of material ( Will have the asbestos professionally removed!) Any help /advice greatly appreciated
