Description…
The MSR E-Bivy provides easy-to-carry, back-up protection for day hikes, sleeping out and trips away from basecamp.
Features…
Functional – Simple design helps slow heat loss and keeps you dry
Reliable – Coated and taped Sil Nylon is more durable than "space blankets" and keeps you dry
Ultralight and Small – Weighs only 0.2kg (7oz) and small enough to bring anywhere
Versatile – Keeps dew and frost off your bag if sleeping out and adds warmth
Capacity – 1 person
Minimum Weight – 255kg
Packs down tiny. Used once £25 posted
The PocketRocket backpacking stove provides full cooking function in an incredibly efficient form. Barely noticeable in your pack, it delivers impressively in camp. Precision flame control goes from torch to simmer while our Wind Clip™ wind shield boosts efficiency in breezy conditions. The PocketRocket stove’s diminutive size is also the foundation of a solid emergency kit for home or trail.
Ultralight, Ultra-Compact: Weighs just 3 oz. (85 g), with palm-sized dimensions: 4 x 2 x 2 in. (10.2 x 5. x 5.1 cm).
Simple Operation: No need for priming, pressurizing, or maintenance.
High Heat Output: Boils 1 liter of water in under 3.5 minutes.
Full Flame Control: Glove-friendly controls allow precise flame adjustment, from a simmer to a boil.
Flame Protection: Tri-sectional Windclip™ wind shield protects flame and boosts efficiency.
View specs in printer-friendly formatMinimum Weight 3 oz / 85 g
Packaged Weight 4.2 oz / 119 g
Burn time (MSR IsoPro) per 227-g / 8-oz. canister Appx. 60 minutes
Boil time (MSR IsoPro), 1 liter 3.5 minutes
Water boiled (MSR IsoPro) per 227-g canister 16 liters
Water boiled (MSR IsoPro) per 1 oz. of fuel 2 liters
Used few times £15 posted
XGK Multi Fuel Stove, used a few times a year for past 6 years. Great condition though and serviced regularly.
Burns pretty much anything!
