Front derailleur fo...
[Closed] Front derailleur for a double chainring set up?
[#2821638]
So I've fitted a 27/39 double chainset to my bike.
I've adjusted the stops to minimise how far it can move the chain, and still using a 3 spd shifter, but using just two clicks it seems a bit easy to sling the chain right over and off the outer chainring.
Would a derailleur specifically for a double chainset prevent this? Would I also need a new shifter?
Also, do double front derailleurs sit closer to the chainring? The existing one sits a long way from the chainring, presumably because it would normally be used with a bigger outer ring. I can't lower the existing derailleur because its a direct mount one.
Posted : 05/06/2011 10:43 pm
 Bez
Your 'H' screw is right in, I assume? If not, the obvious solution is screw it in more. I've not had a problem with the stops on Shimano mechs being insufficient for just two rings.
Posted : 05/06/2011 10:55 pm
The 'H' screw is right in.
I might have pulled the cable too taught, so essentially from small ring to big ring, the whole shifting range is further outboard?
I just wondered if dedicated dual ring derailleurs are any easier to set up? And also if they run closer to the outer chainring i.e. like the usual ~2mm gap from a 44t outer ring but for a 39t. Currently the gap on a 39 is massive and I can't get the mech any lower.
I'll persist with the cable adjustment.
Posted : 05/06/2011 11:19 pm
I have an SLX dual-ring front mech. It seems to have a tighter curve to follow the smaller ring.
Mine is standard not direct-mount, so getting it at the right height was just a case of setting it in the right position on the seat tube.
Posted : 06/06/2011 12:20 am
Does anyone know if one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=55252 ]these[/url] fit my Zesty, and also work with a 3 spd (X9) shifter?
I'm having problems with my existing mech firing the chain over the outer ring. Would a bash ring help prevent this and does anyone do a vaguely XC one for a 39T outer?
Posted : 20/06/2011 8:15 pm
Problem is these stupid new standards such as direct mount mech's and press fit bottom brackets, all roadie stuff that isn't needed on a MTB and makes life harder. I'm doing a similar conversion, was told to leave the front mech high up as will aid shifting for some reason, also if the 'H' screw needs to be longer purchase a longer one from local hardware shop and fit, this will solve your problem and be cheap.
Posted : 20/06/2011 8:59 pm
Yep...I have a max of about 5mm adjustment on the derailleur height cos thats how long the slots are in the mech.
I didn't think running 27-39 would be too dissimilar from just ditching an outer ring and running a double and bash...???
I get the feeling that lowering the mech or using a double specific would decrease the likelihood of the chain dropping off on the inside when changing down? Which has also happened.
Good point on the adjustment screw, will source a longer one to start with!
Posted : 20/06/2011 9:49 pm
Yes if the chain can still move over the outer ring your stop screw needs adjusting, so get a longer one. Try your LBS, they will probably have a pile of old mechs to raid. Then it should work perfectly with your existing mech.
Posted : 20/06/2011 10:05 pm
Thanks guys, longer screw first stop!
Posted : 21/06/2011 6:56 am
And just to confuse matters further, i'm pretty sure Lapierre aren't a direct mount(even though they mount directly), but an e-type with the BB mount removed.
Posted : 21/06/2011 7:23 am
Yes, I had a look at Shimano mech's and it does seem the only ones you can get are E-type with the mount to be removed. So that's different from proper 'direct mount' is it?
Posted : 21/06/2011 1:24 pm
I have 27-40 and managed to lock down my XTR front mech enough to work fine.
Posted : 21/06/2011 5:22 pm
