Bottle mounts can be made from M5 nuts – a few minutes in a lathe to knock the corners off half the hexagon leaving a round bit 7-8mm diameter and maybe 2mm long that will sit nicely in a hole. Drill appropriate holes in your tubes then sweat in with silver solder (something like 55% silver off ebay which often comes with a little bag of flux). A MAPP gas plumbing torch is more than hot enough for silver and gives plenty of control – the flux will go clear and tube needs to be very faint red colour – any hotter and you just char the flux. Oxy-acet is fine if that is what you have access to, just go easy / use a small nozzle and keep the flame moving.
Anything more structural / butt jointed is probably better done with brass or TIG rather than silver.
Proper braze on parts from Ceeway http://www.framebuilding.com but postage is steep for just a few bits. I’d also second Steve Goff for a cheap and quick solution if you don’t want to diy (he’ll have drawers full of braze-ons).
