Hai need some helpz from the internets.
I got a MTB from Merlin Cycles about 2 years ago. Which was all very good.
Then about 1 year ago I took it into a Bike shop to have it serviced. Nothing majorly wrong with it but it needed TLC.
Anyway I get a call 10 minutes later with the Bike engineer saying theirs a major problem. Apparently on the frame where the bottom bracket screws in the frame wasn't 'finshed off' i.e when the tube part was cut in the facotry it wasn't filled down properly.
This meant the bottom bracket didn't go in straight but more importantly when the engineer took it out to have a look at it it then cross threaded the thread on the inside of the frame
The guy in the shop said it was a malnufacturers fault with the frame and that most frames are gaurenteed for 5 years.
The shop I got it off however says there wasnt a problem untill the guy removed it so it's not their fault.
I can post pics tonight if it helps, but has anyone ever come across this problem? Or any advice or pointers would be greatly appreciated.
— Sorry for the long post
Dirt Licker
