I’ve got some van 180mm forks fitted with an extra firm spring, i really do not find it stiff enough, issue is bottom out and support, support gets ok if i crank up the damping, but bottom out issues are still there. A bit of preload gets me to 20% sag, im used to running 15%ish on my trail bike.
I weigh around 185lbs kitted up, the extra firm spring is rated for 205-240lbs, so im well below recommended weight.
Is it a fact of life with coil forks, ie that linearity of the coil just means this is what im going to have?
Maybe coil isn’t right for me?
What do people reckon, just get used to them? I just dont find them that confidence inspiring when it comes to hucks.
