Have a set of 7 year old TALAS forks. Been pretty good apart from regularly chewing through stanchions. After the 3rd replacement set I decided that given the age of the forks I'd run them until failure, and have just changed the oil on a regular basis.
However, noticed over the last few months a gradual reduction in travel and failure of the TALAS height adjust. Reluctant at this point to hand over £100 to have seven year old forks serviced so decided to leave it.
This morning, when adjusting the pressure after the bike had been stored upside down, a load of filthy greeny-grey, thin, oil squirted back through the shock pump. After initial panic subsided I discovered that the forks have regained full travel and the TALAS works again.
So… how important is this oil that was, rightly or wrongly, in the TALAS chamber (which should be isolated from the oil elsewhere in the fork)? There is a slight scraping noise on fast rebound, but I think it's the worn stanchions and not the TALAS shaft.
