Fox forks = poo poo...
[Closed] Fox forks = poo poo?
[#5336029]
They look good and that's as far as it goes other than that total over priced but ok for trail centres I suppose
Posted : 16/07/2013 7:02 am
I'm not over-enamoured by my Fox rear shock either. I paid extra for it as an 'upgrade' on my bike, but so far it's on it's second warranty visit. The juries still out, but I'll not be tolerating a third warranty return. My Rockshox forks on the other hand, have been nothing but faultless. As for being overpriced, well at the end of the day they're cans of air, there is not much to them in terms on new or high technology, so yes, they're a rip off. But then again this is cycling. Everything's a rip off.
Posted : 16/07/2013 7:12 am
pinhead - Member
What makes them OK for trail centres? I'm baffled by that.
Also, open a set up and you'll see where your money went.
Posted : 16/07/2013 7:20 am
Double post
Op...the hot weather getting a bit much for you?
Posted : 16/07/2013 7:22 am
Which fork / issues have you had ?
Posted : 16/07/2013 7:23 am
Must admit, I blew up a set on the 2nd day of use....second pair appear to be doing better.....I did find it strange considering I wasn't really hammering them.
Posted : 16/07/2013 7:24 am
It's an elitist dig, the OP's too cool for trail centres which are too easy, he has to ride 'proper' trails, which need better forks 🙄
Posted : 16/07/2013 7:48 am
[quote=njee20 ]What makes them OK for trail centres? I'm baffled by that.
He probably rides all day on boggy trails dodging dog eggs and walkers testing his forks to the Max with dials at 11 too.
Just got my new ones and love them, the last lot are on the HT 06 36's going fine.
Posted : 16/07/2013 7:51 am
They look good and that's as far as it goes other than that total over priced [b]but ok for trail centres I suppose[/b]
I don't understand what you are saying here. Why would they be ok for trail centers if you deem them bad? Do you consider trail centers not to be a full work out of the forks?
There are so many threads dissing Fox forks. I think it's two reasons:
1: Service intervals are quite short (officially)
2: They are so common/popular that they are likely to have more issues reported
I have Fox forks and they need attention, but then I haven't touched them in 2 years. I do worry that if I leave them I will get Stanchion wear so I need to look at them. However, in terms of actual feel and performance...fine. They work and feel plush to me. I'm not sure how much better "better" forks could feel for me and my riding.
Posted : 16/07/2013 8:29 am
I've only ever owned one set of fox forks, 2011 180 rcs vans with that kashima coating, they worked ok for a few rides and the performance was ok but not mind blowing, then the creaking started, after 3 new CSU's within 18 months I got shot of them, it also seems like the issues are still going on http://forums.mtbr.com/shocks-suspension/2011-fox-forks-creaking-cracking-noise-711911-post8082272.html
I'm now on a set of 2012 marzocchi 55's the ti ones,
whilst they perform way better than the fox's, guess what? they've started creaking too, they're going back for a warranty replacement CSU once they have stock.
I'm currently under the opinion that all modern high end forks are rubbish, if you ever strip them down and see just how little is in them your just left feeling a bit ripped off
Posted : 16/07/2013 8:41 am
Was a bit concerned about perceived reliability of the Fox 140 TALAS forks that my Stumpjumper came with.
But, in reality they've been brilliant. Haven't been serviced as often as 'required' but are still operating fine. They can sit unused for several weeks and work fine striaght away, they don't leak oil, they are consistent, the air spring never needs topping up....
Whereas my 2008 Reba's have been a real pain. They don't seem to maintain air in the spring side very well, they require more frequent servicing or the damping goes to pot, the lockout sticks, they leak oil profusely in warm weather when the bike is turned upside down...
Only thing I don't like about the Fox is that grit gets caught between the lockout dial & the rebound dial so if you use the lockout, you invariably twiddle the damping too, which is a pain.
Posted : 16/07/2013 8:55 am
I'd only ever ridden mine at trail centres, then I took them down a canal towpath and they vapourised. Would you believe it?
Posted : 16/07/2013 9:11 am
Mine are way, way better than the Pace forks I used to run. They were a bloody nightmare!
They're like the iPhone of the fork world.
Posted : 16/07/2013 9:22 am
Shock guru in the house!
Posted : 16/07/2013 9:42 am
Sounds like they need new air seals, especially as they are 5 years old.
The leaking from the top cap means can be fixed for 25 pounds if you take it out and send it TFTuned. Theres an "umbrella" seal in the motion control unit that needs replacing. Its reverse threaded if you want to take a look yourself. Some people have just put a rubber seal on the threshold adjuster, but that just stops the oil coming out the top rather than fixes the damper.
Posted : 16/07/2013 9:46 am
I used to get on fine with the old RLC damper but I don't like the new CTD. I haven't tried the CTD adjust yet which might offer enough adjust-ability so I can adjust to my liking.
But its the cost of the forks that really puts me off. Far more expensive than the competition and for me anyway no benefit. If the forks came as part of a full bike the costs don't seem to be too high so don' think I'd mind too much but I don't think I'll be buying one after market any time soon.
Posted : 16/07/2013 9:48 am
my 03 float rlcs have taken a battering, the stanchions are a bit worn and scratched, the enduro seals were a big improvement, I had to get LoCo to fix my rebound cartridge and the lockouts intermittent
theyeve been all over the UK, megavalnche, spain etc etc
they are on my xc bike these days and while the arent as plush and controlled as my 44rc3tis they still work
however
[b]RRP for the equivalent model is 3x what I paid for them ten years ago[/b] which imho is ridiculous
Posted : 16/07/2013 9:53 am
I'm a hater when it comes to Fox forks.
They were the least resilient of anythin I've had.
RS faired little better. Neither lasted more than 9 months from new before waring through the stanchion coating. They'd both had lowers off and oil changed at about 3 month intervals.
2010 Marzocchi ti coils have been excellent for me though. Oil changed annually and still on original seals/wipers. So much nicer to ride and far more resilient.
Posted : 16/07/2013 9:57 am
This is the only thing I've found was a problem with my Fox fork
( I now have Rockshox though)
Posted : 16/07/2013 10:03 am
Supposedly this year's damper fixes the diving problem of last year, it had better tbh as they were terrible out of the box. But that won't fix the high price, and the flex of the 32s, and the essential ropeyness of TALAS.
Posted : 16/07/2013 10:23 am
I really like mine - a pair of 2005 36RC2's with the Talas removed and swapped to Vanilla internals. They get serviced once a year and are still in their original stanchions. They seem plush, adjustable, stiff and reasonably light for a 160mm coil fork.
My previous 32 Vanilla's were great forks too. I've never had issues with stanchion wear band yes, I do ride my bikes). I've never quite gelled with Rock Shox forks for some reason. I've had a few pairs of Boxxers and not liked them and the first pair of Pikes I had were a pain in the bum.
I'll get some 55 RC3's when the 36's die having been a Marzocchi fan boy for a long time. I wouldn't buy any fork new they're all over priced. Lyrik's aren't cheap the only difference is that they get discounted. Hopefully X Fusion will shake things up a bit with regards to costs.
Posted : 16/07/2013 10:26 am
Just put some x-fusion slants on my Nomad. They seem very good out of the box and cost half what Fox are charging. Time will tell on durability, but x-fusion could be taking a big slice of the market at this rate.
Posted : 16/07/2013 10:42 am
What does CTD or RLC mean and stand for? I cannot find this on google.
Posted : 16/07/2013 10:50 am
The new price is eyewateringly large and hard to justify
Despite the ropeyness claim I like my TALAS
granted you take a choice of performance for adjustability v the FLOAT
Posted : 16/07/2013 10:51 am
CTD: climb, trail, descend
RLC: Rebound, lockout, compression
I thinks
Posted : 16/07/2013 10:54 am
I thinks
Yep got it right.
The RLC had adjustable low speed compression tune from fully open to lockout. So I could add a tiny bit of compression damping to stop the front end diving too much but still kept it supple enough over the small stuff.
The CTD has 3 pre-set positions, in descend mode its far too open and dives everywhere and in climb mode is far too stiff and doesn't track well over smaller bumps.
Posted : 16/07/2013 11:14 am
Trail centres are groomed man made tracks and designed to be rode zzzz
Lakes,munros peaks non classic etc warrant a fork which is both reliable and up to the job
Pal
Posted : 16/07/2013 5:22 pm
Posted : 16/07/2013 5:38 pm
Yeah. Minaar, bryceland, peaty, the athertons, blenkinsop, etc etc loves them trail centres.
Posted : 16/07/2013 6:47 pm
Industry boys riding trail centres shock horror
Posted : 16/07/2013 6:59 pm
I'm not sure if you're trolling or just plain thick!
Posted : 16/07/2013 7:05 pm
Ey Pal c'mon now think about it
Posted : 16/07/2013 7:23 pm
Glad I just sold mine.
They were ok but as they were n my holiday bike probably only got used for 30 days or riding, 6 or 7 hours a day.
I couldn't live with the servicing if they were n my UK bike!
That's got Rockshox
Posted : 16/07/2013 7:53 pm
Pinhead please explain what you mean by ok for trail centres, what are they not ok for?
I have had a few sets. Find them ok for mot things. Think the FIT damper feels better on the small bump than the older open bath system.
Have had to replace a CSU due to wear as there is little lube oil in the TALAS side leg.
I would like to try so Marrzochi 55 TI but they are pretty costly too.
I guess im open minded to the strengths and weaknesses of fox forks. I just dont understand your original post...
Posted : 16/07/2013 9:22 pm
Performance of the 2013 stuff is leagues ahead of previous generations. You can also run more oil in the spring side of the air forks without knackering them, which will help longevity.
I lube the seals with Float Fluid every ride anyway. My 2003 TALASs wore out three sets of stanchions in 7 years. The 2010 Floats had no wear after three years, and we'll see how I get on with the Factory Floats on the Sight.
Posted : 16/07/2013 9:58 pm
I must have serviced 20+ sets of Fox forks this year (I've done 3 this week). I've probably seen the inside of more forks in general than all but the Big Boys like Loco and TFTuned.
I've only ever seen one set of worn Fox forks which are actually sitting in my garage as I type. They're 8 years old. I've done the seals and a service and I reckon they'll go into double digits as they are. Which is pretty good in my book
Posted : 16/07/2013 10:14 pm
PeterPoddy - Member
POSTED 1 HOUR AGO # REPORT-POST
You must be clearly bull shitting there
Forks are by far the weakest and most vulnerable to damage/wear than any one other by far!
Marzochi are for real riders!
Posted : 16/07/2013 11:24 pm
[u]Fox[/u] Forks are by far the weakest and most vulnerable to damage/wear than any one other by far!
Posted : 17/07/2013 7:26 am
We do see a trashed csu at about one a month on the bikes that come through the workshop
But Personaly I like most of my fox forks ( 34 talas seem rather poor but getting sorted slowly) and with tlc they last just fine.
One of my riding pals wore the coating off his lyriks the parts would have been about £400 to get fixed
Even with recent price rises fox are half that
Posted : 17/07/2013 7:49 am
Which part?
Because I'm not at all.
I've done 4 sets and one rear shock for one person alone this year. I was thinking 20+ sets purely based on how many 1l bottles of 10w suspension oil I've got through recently. 5 forks per bottle, and at least 4, 5, 6 bottles.....
I only do Fox and Rockshox, but I service a considerable amount of them, and shocks too. Bring your forks along, I'll teach you how it's done.
Fox are not as bad as people who know very little think they are.
Posted : 17/07/2013 7:57 am
Which part?
If PW says you are then you must be:)
Posted : 17/07/2013 8:06 am
Back in the day, Fox stanchions were pretty crap (going back 10 years plus), but my recent forks have been fine. Prefer the action of Fox over Rock Shox and Marzocchis I've owned and the weights are good too.
Posted : 17/07/2013 8:09 am
The last pair of Fox I had were F100 RLC's & they were mint after 3 years riding when I sold 'em. Been on SID's for the last 3 years and, despite regular servicing, are showing signs of wear & a creaking CSU - all normally "expected" on Fox.
Just picked up a used set of F Series which are the same age as the SID's yet immaculate by comparison.
Posted : 17/07/2013 8:29 am
