Don’t want to scare anyone but TF tuned told me that the Enduro seals can wear the anodising. The recommended Manitou seals for Fox – my first reaction was “is that the only thing Manitou make that’s any good?” To which they said…
…and on my 08/09 TALAS the seals were easy to replace. The instructions on the Fox site are easy to follow I thought. All you need is damping oil – you only need the float fluid if you’re stripping the TALAS assembly, which isn’t usually neccessary.
The standard weight fluid is 7.5, but 5 id OK as you can dial in a bit more rebound & compression. Don’t use 10 tho.
