The above forks (150mm travel spaced down to 130mm) have developed a problem I haven’t had before. The first few mm of travel seems to be accompanied by a ‘click’, or a ‘creak’ noise. This happens when I get on the bike or if the fork is fully extending and then compressing again, eg when going up a hill and honking out of the saddle. Also seems to be accompanied by a reduction in travel which seems to be caused by oil from the lowers getting into the air chamber. I’ve previsouly got the extra scraper seal which is supposed to fix this.
If I grab the lowers and try to rock them backwards and forwards, then I can reproduce this click, but its hard to say if it is due to back and forth movement, or just a tiny bit of compression.
If this something that replacing all the seals myself is likely to fix, or does it sounds like something bigger? Bushes worn? The stanchions are fine – I drop the lowers and do the oil change thing regularly so I thought wear on bushes was unlikely.
