I’m currently putting together my Alpine 160 fitted with Fox 36 (FIT RLC) forks. I have come to fit the discs that I have and have hit a snag.
Wheel is a Mavic EX721 built on a Hope Pro II hub alternatively I use a Superstar Voltage wheel set or a Specialized hub but ALL have the same issue. The disc I was going to use is a Hope 203 floating rota, problem is the disc rota arms foul the post mounts on the forks. When I fit a standard rota the clearance opens up but even then it’s only 0.012 – 0.015″ (roughly 1/4mm) has anyone else experienced this and if so was there a way to sort it without resorting to filing the inner edge of the post mount?
Oh, the hub spacers are symmetrical but I tried swapping them over just in case to no avail. 🙁
Rod
