26 inch Mattocs have the same lowers as the 27.5 version, just a different crown/offset. You can then move to 27.5 inch wheels later with the same fork by adjusting the internals and have a fork thats more stable on the downs due to the lower offset than the 27.5 version.
Supposedly. If you went the other way round, a 27.5 inch fork with a 26 in wheel – then you might end up with twitchier steering due to the increased offset.
Also the travel is internally adjustable, which is good – the only fork that does it at the price point you can the mattoc from Germany is the 350cr which has more basic internals. You’d be getting a fork with high speed and low speed compression adjust, dual flow rebound circuits, hydraulic bottom out adjustment.
The ones to buy are the expert and the pro – the expert is 100g heavier as I think it uses the internal wall of stanchions to pressurize the oil whilst the pro has a cartridge design. Although bother get all the same external adjustments I’m not entirely sure if the damping differs in any other respects.
