Viewing 4 posts - 1 through 4 (of 4 total)
  • fork presures – help
  • fastindian
    Hi, im running mazz XC 600’s but even at the lowest recomended presure settings im not getting anywhere near full travel. Do you run yours under presure and if so, what?
    uplink
    How are you measuring full travel?
    MrNutt
    are you using a low pressure pump, fox use high pressure pumps and ‘zocchi use low
    PeterPoddy
    Lack of tralvel isn’t necessarily due to the air pressure setting.
    You could have a problem with the forks – When were they last serviced/how old are they?
    You just might not be riding hard enough!
    Does it feel bad that you’re not getting full travel?
    How far are you off it?
    Set them for 20-25% sag and that should be about right.
The topic ‘fork presures – help’ is closed to new replies.
