Hi all,
I have a Blur TRC that I have boosted the travel on slightly. I now have ~140mm rear travel instead of 125mm. I’m running a CCDB Air CS with a few additional Mm stroke (same e2e). I rode it this weekend and it’s turned the bike into an absolute beast- probably more due to the shock (over the old RP23 it had).
The build is geared towards general ‘Enduro’ riding with 1/10 gearing and a dropper. I’m using a Fox 32 RLC FIT (with a custom tune) at 150mm. The current weight is a smidge over 25lbs.
Overall the ride is excellent, I am very pleased with the set up and the weight of the bike- it’s perfect….or so I thought.
Yesterday I was riding some downhill trails for a change (I also had the DH bike with me but fancied a run or two on the short travel rig). I often do similar riding as part of a longer ride.
One thing that was REALLY noticeable yesterday was the flex of my 32’s. The improved handling of the rear end really made me aware of how flexy and unpredictable the forks are under heavy braking and loose rocky/rooty chopped up sections.
So, I think I would like to run a slightly beefier fork- maybe Fox 34’s or a Rockshox Pike. I really don’t want to add more weight but I think it would be worth it for the extra control.
My current fork is around 1700g I think.
Do you think it’s worth upping the fork to something a tad heavier? Also any suggestions for a light
Ish 150mm travel fork?
Cheers!
