Fork lockout musing...
[Closed] Fork lockout musings/bodging - cable pull/thumbies/gripshift
[#3771878]
Pretty much just because I enjoy playing around with bikes, I'm toying with ideas about fork lockouts. I was thinking that a low profile gripshift might actually be a very neat way to do it. Or otherwise a small thumbie. Anyone know what the cable pull for an RS poploc is?
Also, suggestions on a low profile gripshift? I seem to recall that the older (eg original Xray type) gripshifts were smaller than the current models
(as an aside, while googling I found people have been using poploc remotes as front shifters for doubles - interesting idea...)
Posted : 14/03/2012 12:15 pm
No fellow bodgers about today?
Posted : 14/03/2012 4:12 pm
the old pace lock outs for the hollowforms were nice
Posted : 14/03/2012 4:15 pm
Yeah though they were very short cable pull as I recall.
Posted : 14/03/2012 4:18 pm
Whats wrong with the Poploc?
Posted : 14/03/2012 4:23 pm
Poploc's ok but I quite like the idea of a gripshift...
oh and I might want two on a bike (fork and shock)
Posted : 14/03/2012 4:26 pm
I've tried a thumbshifter, works quite nicely and gives remote variable compression adjustment. It does stick out quite a bit from the bar though so would be vulnerable in a crash.
A grip shift would be nice and low profile but you'd need a lot of bar space to fit everything in.
Posted : 14/03/2012 4:36 pm
That was kind of my thought - at present, poploc is on or off. With a gripshift, you could, depending on the cable pull, tune the compression damping.
Anyone know the cable pull of a poploc then?
Bar space could clearly be an issue though I'm sure that older GSs were shorter than the current ones.
Posted : 14/03/2012 4:40 pm
Why don't you just use an an adjustable compression pop loc?
Posted : 14/03/2012 4:58 pm
if you could find an old raleigh chopper gearchange that would look propper niche on the top tube
Posted : 14/03/2012 5:30 pm
Is that how they work though? Aren't they either ON or OFF? Are all shocks and forks progressive like that?
Posted : 14/03/2012 5:33 pm
Doesn't work very well, not strong enough.
Posted : 14/03/2012 5:42 pm
Yes you can use a thumb shifter instead of the rockshox remote. You get kinda adustable compression. Mate did exactly this with some rebas.
Posted : 14/03/2012 6:00 pm
Yeah, it works exactly the same - the remote version of the damper is basically just the same as the non-remote version but with a spring.
adjustable compression poplocs still only have two settings but you can adjust how much compression it has while in the unlocked position.
Posted : 14/03/2012 6:12 pm
I love bonkers idea's like this!
Give me call at the Evans Suspension Centre tomorrow and i'll tell you much cable pull a pop-loc has 🙂
Posted : 14/03/2012 9:18 pm
it's OK I'm home and have one here to measure 🙂
so, a poploc remote pulls approx 20mm of cable.
a front shifter conveniently also pulls a near identical amount.
so, in theory a front shifter with trimming (eg not just 3 positions) would allow fine tuning on the fly.
Posted : 14/03/2012 11:09 pm
boink
Posted : 15/03/2012 10:39 am
