Viewing 4 posts - 1 through 4 (of 4 total)
  • Fork Bushing replacement
  • barrykellett
    Have any of you replaced the bushings on your forks? Rock shox pike 426 needing done here.
    Was reading the SRAM tech manual online and it doesnt seem that difficult a job at all, but the specialist tools aren't readily available on the net as far as I can see.
    Anyone know a good source for the bushing pullers and the punch bit to put the new ones in?
    I would rather have a go at it myself, even if buying all the bits totals as much as sending the forks off to TFT. There's a couple of pairs of Rockshox in the family fleet so the tools would definitely be getting a good bit of use over time
    barrykellett
    Nobody?
    nickegg
    I hope you really know what you're doing…..
    I think there's a reason the removal tools aren't readily available.
    I would just send them to TFTuned if i were you.
    thejesmonddingo
    Look at Enduroforkseals.com,they've got a pictorial of replacing a dual air Pike's bushings,it's probs very similar
    Ian
The topic ‘Fork Bushing replacement’ is closed to new replies.
