It probably wont have a gasket so to speak, its usually a bead of sealant these days.
Getting them off is tricky, but there is usually a bit where you can hit it from above with a long bar / screwdriver. This is usually advised against, & the dealer has a “special” tool for prying them off. It doenst affect you though, as your binning the old one. Get the engine nice & hot before you drop the oil out & its should be easy enough. They usually take a bit of a wack though….
You’ll probably have to take off a pulley cover or guard or two before you get to it, & obviously any belly pan.
Be warned, its about as messy job as you can tackle. Leave un-sumped car to drip onto an old sheet for an hour before you crawl under. 🙂
Have you tried patching it ?
I got one to seal once. Drained the oil, wire-brushed & degreased & filled with Belzona. Went on for another few years.
