Assuming you have finished on the gravel by the road/pottery you could try the following. turn right on the gravel and follow it for about a mile and up a hill to a junction. Left and you can see a factory (look out for trains , they end old ones here) down to the right. Several little lefts here take you down to a stream,(try the power line one) .Miss the lefts and you reach the road , say hi I live behind the trees to the right. Follow stream either on right side to road just below pottery and right to Parkend, pubs and then cycle track. in the cut area before the hill there were some nice little bits of track but timber cutting has screwed those.
Back to the stream. Go along track to left of stream to the road as above. Niether big loops but a change to get you to Parkend.
Alternatively cross road by pottery, along little road to cycle track and instead of following it right go left. As you reach Point quarry go thro' it and work you way up then sort of north and then down and back to Cannop crossroads. Or ignore point and keep on up gravel. at road go around end of barrier and up steep little track. Cross gravel, up narrow stoney track to flat. following this takes you to Broadwell dips above the tip. dropping down and right anywhere here is good to cannop. Crossing road puts you above the marked downhills to centre. At road crossing follow gravel to downhills or up tar then right to windies to down hills.
Any good?
