After all the conversations on here about the advantages of riding flats every once in a while, I thought I'd give it a go. What do people think to eith the Shimano DX30 (Shimano stuff just seems to work) or I did see some NC-17 III things that looked rather nice.
Anything else in the £40 ~ £60 bracket worth a punt?
Went for the DX's when I moved from SPD to flats about 3 months ago. Heard so many negative things about various types, I went with Shimano because they are a good size, OK thickness, and especially because I don't want to have to maintain them. Very happy with them, paired with 5-10 Freerider shoes
Yes, I have the Shimano ones and they are absolutely fine. You may fine when you're a flat pedal "expert", that you want something else – well go buy them when you know what you want. In the meantime, the Simano ones are trouble free, grippy and big enough to put your foot on.
I have tried, V8/V12 (too small if you have feet over size 10, and will give you cramp), Straitlines (very nice, but very expensive and sqweak), AtomLabs TrailKings (axle falls off), Wellgo B54 (crap bearings, which go crunchy in weeks), Azonic Mag thingies (which were shit).
Straitlines here but I doubt I would have paid RRP for them. Rich, you can shut them up dead easily, just pop the circlips off the end, slide the axle out, give it a clean and a grease and that's it. 5 minute job if that.
Kona Wah Wahs seem to get a lot of love round these parts.
Old Azonic A-Frames x2: Can't fault em
DMR V12 – Too Small
DMR V8 – Likewise
Gusset Slim Jims – Need longer pins, but good
Wellgo B-54's – Seem good but time will tell on the bearing front.
I got all nostalgic and really wanted some Shimano DX like I once had on my BMX 20 years back but the new DX are far too heavy. There are cheaper and lighter alternatives already mentioned, but may I suggest you go for a pair of NS Bikes Ariel flats. 😀
They are too small, as the edge of your foot rolls over the side and after a while gives you foot cramp. The platform needs to be wider to support your foot and stop this arching.
still a bit dubious… maybe I'm blessed with a very straight foot position, but I reckon you'd have to be quite bandy legged and/or not have stiff soled shoes to suffer.
I'm now torn between the DX-30 and the MG1 having seen them both in the flesh. The NC-17 sudpro III keeps calling to me and I'm really not sure why. Doesn't seem that anyone else has ever bothered with them.
These Straitlines – no sealed bearings is there? For £90 I would expect them to have.
But … lots of people are recommending them so are there any shops in the South where I can actually look at them please? In fact I could be really geeky and take my pedals with me to compare 🙄
No, they run on bushings, which makes them a total doddle to service. They are a bit draggier than bearings and they can go stiff and seize, so they're not maintenance free, but they seem pretty bombproof compared to previous pedals I've had (Crank Brothers Mallets, V8s, and some Specialized Mags that ate themselves after the bearings seized).
One set three years old and no problems. Second set 1.5 years old and no problems. Been bashed and thumped on uplifts, The Alps and Canada. Been great pedals for the price. 50/50 were guff I though.
Is this the secret to your (un)success? If I use such a combination am I guaranteed to become a development rider for a small British bike designer (not that Brant is small or designs small bikes, but you know what I mean)?
A wonky right foot means no SPDs. Trail running shoes are light and dry fast.
the 'too small' comments are all personal preference. For what its worth i used v8s before and until i tried 50/50s didnt realise how much difference a bit of extra width could make 😯
They are much more supportive and give a bigger platform to stand on.
I guess it also depends on the size of your feet and stiffness of shoe.
Using the Straitlines currently but the internals have not lasted at all well. Had to buy the service kit of replacement parts which costs more than some V8s!
Very grippy until you eventually slip. Several scars below my calf as evidence now.
Shimanos are ok but i could'nt remove the (way too) short pins to swap out for longer ones, bearing in mind there are 40 in total.
have you tried wider pedals then Mike? as you might see what people are on about if you do. Then again you might not
The Planet-X pedals I had before were wider; can't say I notice any difference. I've not had foot cramp on my MTB, but have on my Mundo, which has very narrow pedals.
I'm convinced that your feet get used to taking your weight on narrower pedals, so you don't get problems. Anyone switching to narrower pedals suddenly will probably have problems, but if your feet are used to the narrower epdals, you won't.
