I lost a load of the fins off the collet on my old command, brought new collet and was told by local dealer it was a really fiddly job that would take a complete strip down and they would need the post for a couple of weeks to do it!! Instead I got them to order the part, then did it myself, it was easy,
Unscrew the retaining cap to separate the base from the post (remove air first) pull apart, I had to spend a bit of time getting the mashed bits of collet out of the base as they had wedged into the groove so took a bit of faffing and a mallet.
For some reason I ended up undoing the screw that holds the cable into the bottom part under the collet, but I should never have done that, just made things more fiddly, realised after all you do is unscrew collet (mine undid with ease using a big adjustable I think. That will then slide over the gubbins, ready to acre the new one on. Easy!
If you need any more detail il try and write it a bit clearer but am on my phone in work at the mo but hopefully that gives you an idea. I had brought a reverb when mine initially broke so once fixed I fitted to my hardtail and that was about 2.5 years ago, still going strong.
