Viewing 5 posts - 1 through 5 (of 5 total)
  • fitting hinges to integrated washing machine door
  • bitasuite
    I’ve got a door that will cover the washing machine but need to drill it for the hinges. Where could I get this done?
    Anyone know what tool is needed to do this? Is there a standard jig?
    Many thanks
    Blazin-saddles
    Ha, The bain of the Kitchen fitters life!
    You need a 35mm TCT Hinge hole cutter and a steady hand, or a drill press/router ideally.
    There’s no jigs available I don’t think, I always mark up carefully, and drill by hand if having to do it on site with my plunge router. I usually set the hinges on the machine then measure down from the worktop, remember to allow for door offsets. Drill a bit at a time as on thin doors (15mm) the hinge hole will be nearly all the way through the door.
    wwaswas
    http://www.axminster.co.uk/cabinet-hinge-installation-jig-bit
    Bit plus marking out jig.
    You still need to measure where on the door to put it though.
    Blazin-saddles
    The jigs are for normal cabinet hinges, which can be different offsets to washing machines. hand marking is a better way for me.
    bitasuite
    Thanks guys
The topic ‘fitting hinges to integrated washing machine door’ is closed to new replies.
