Why I ask ? My Process has just had its third set in as many years , first time fitted “dry” , second time (different bike shop ) they use Enduro Max bearings said they always Loctite them in , sounded convincing thought it was going to be a long term solution that’s the correct way apparently?, that didn’t last more than 5 months ! Ongoing issues with the bike meant I got Kona involved , just had ANOTHER set fitted by a Kona dealer (Kona’s own bearings?) showed me the old ones , some of the Loctite had gotten behind the bearings and wrecked the seals ! To quote the Kona Dealer ” Anyone who Loctite’s frame bearings in is an idiot ” ???
Before the Loctited bearing job was done I E Mailed Kona’s Tech guy he reckoned there was no right or wrong way just down to personal preference ? Why is there no consistency? Doing my head in especially as I’m not convinced changing bearings is going to cure the ongoing issues with the bike . After a bearing change bike works fine for a while then develops a graunch/Creak type noise under load which no one can identify? Yes all the usual suspects have been tried . So far I’ve thrown the fat end of £3 to £400 at the problem , doing my head in !
