DAB might be on or off, but FM can be unbearable when it just breaks up into unintelligible white noise, with no clear reception for miles, like it does, or did, around Chippenham, Bath and Bristol. I would lose R2 on the outskirts of Chippenham, and not get a clear signal until close to the centre of Bath, that’s nearly twelve miles. My DAB, with a tiny little wire antenna stuck inside the windscreen gets 6music all the way into Bath and Bristol, with one tiny blank spot in Box. I’ve even driven down to Burnham-on-Sea, with clear digital reception all the way except for a short section along the M4 just south of the Avonmouth elevated section; that’s getting on for sixty miles.
If I could be arsed, I’d get a proper roof-mounted DAB antenna fitted, but it’s not a priority, if I lose reception, I just switch to the Pod.
