I have a proper first world problem in that I have too many bikes and one needs to go! My main issue is both bikes are essentially brand new, but I can’t properly ride either due to a knee issue. So I’m looking for opinions!
Currently I have a 2013 26″ SC Blur TR with Fox Factory Shock/Fork and a stealth reverb post and I also have a 2014 650b Mondraker Foxy R with Fox Evo Shock/Fork, one of them has to go as they are both too similar in their intended uses.
I am slightly leaning towards keeping the Blur as its red and I always wanted a Santa Cruz, but part of me thinks to keep the Foxy as it is the new technology, despite it being heavy.
Basically I’d like a response from the Poll as to which bike you would rather keep, if you were in this situation. Pictures and Spec below to help you decide!
If you’d like to give a reason to your choice as well that would be great!
Frame: Foxy 27.5″ Stealth Evo-alloy Zero Suspension System FG 140mm
Rear Shock: Fox Float CTD LV Evolution 200×57mm
Fork: Fox 32 Float 27.5″ CTD FIT Performance 15mm 140mm Tapered
Front Derailleur: SRAM X7 High Direct mount
Rear Derailleur: SRAM X9 long cage 10s
Number of Gears: 20
Shifters: SRAM trigger X-7
Chainset: SRAM S1000
Chainrings: 38/24T
Bottom Bracket: SRAM GXP
Cassette: SRAM PG-1030 11-36T 10s
Chain: SRAM PC-1031 10s
Pedals: Not Supplied
Brakeset: Formula C1 180mm
Handlebars: Mondraker Foxy R custom design 31.8mm 740mm
Stem: Onoff Stoic FG 30mm
Headset: Onoff Integrated Tapered 1-1/8″-1/5″
Grips: Onoff Paw lock-on
Wheelset: DT M1900 Spline 27.5
Front Tyre: Maxxis Ardent 27.5″xx2.25
Rear Tyre: Maxxis Ardent 27.5″xx2.25
Saddle: Mondraker Foxy R custom design
Seatpost: X-Fusion HiLo Remote 31.6mm
Weight: 13.3kg
Frame: Santa Cruz Blur TR 2013
Rear Shock: Fox Float CTD Factory 200×51mm
Fork: Fox 32 Factory Talas 2012 110-140mm
Front Derailleur: Shimano XT
Rear Derailleur: Shimano XT
Number of Gears: 18
Shifters: Shimano XT
Chainset: Shimano LX
Chainrings: 36/26T
Bottom Bracket: Shimano XT
Cassette: Shimano XT 9Spd
Chain: Shimano Dura-ace/xtr
Pedals: Shimano M540
Brakeset: Avid Trail 9
Handlebars: Easton Haven Aluminium
Stem: Thomson
Headset: Hope
Grips: Odi Ruffian
Wheelset: Hope Pro 2 on Stans Crest
Front Tyre: Nobbby Nic 2.25
Rear Tyre: Nobby Nic 2.25
Saddle: Fizik Gobi
Seatpost: Rockshox Reverb Stealth
Weight: 12.5kg?? (haven’t actually weighed it)
Keep whichever you enjoy riding the most, or the Foxy if you plan on changing bikes soon, as that’s certainly more futureproof. I have a Blur TRc and wouldn’t want anything else 🙂
you didnt say you’d ridden into a brick wall on the Mondraker, bending the toptube? I’d claim on house insurance for a crash replacement?
Or just sell it as it is ABSOLUTELY BLOODY GOPPING.
Keep the Blur, a bike (or manufacturer at least) that you’ve aspired to own, possibly build it with the choicest bits from both bikes? Put the other bits on the Foxy frame, then bury it at the bottom of a deep pit in the stealth of night.
