I’ve resisted tubeless up to now due to perceived faff, but my new bike came with tubeless ready wheels and tyres (WTB TCS wheels and Wolverine tyres) so I thought I’d give it a go.
Got some Stans valves and sealant, put them in and the tyres inflated no problem with a track pump and 75ml of sealant. Bounced the tyre around and left overnight with no pressure loss, went out for a shortish ride, no problem and I liked the feel of them.
Then today I went for a longer ride. Tyres pumped to 30psi, then about 3 hours in the rear goes soft. I thought maybe it had burped so I pumped it up and it went soft again immediately. So I examined the tyre expecting to see a small hole with the sealant trying to seal it – nothing. Then it was clear the air was coming out between the rim and tyre and the spit test showed air leakage at several points around the rim. I tried shaking the sealant into those areas, but it wouldn’t seal. Had the pressure up to around 50psi, but still no seal. The rim is undamaged.
Eventually in the rain and midges I broke the bead off – still loads of sealant inside – and put a tube in.
So what went wrong? Not had a puncture on the trail in 2 years so not really impressed with the whole tubeless reliability and lack of faff…
