Finished my 1x9 set...
[Closed] Finished my 1x9 set up - sharing some pics
[#3573921]
Hey all.
Thought I would share my pics of my 1x9 set up I did at the weekend on my 2010 Boardman Pro HT.
Was pretty easy actually.
I fitted a New SLX crank and bottom bracket along with a Blackspire 32t chainring and a KMC X9l gold chain.
I thought it would need a chaindevice but after a test ride of about 10 miles and hitting a flight of steps on a foot bridge the chain didn't come off and the ride was flawless. 🙂
I did not use the 'add two links method' of setting the chain length, I just looped it on the two largest rings and looped through the rear mech and decided what tension I was happy for the rear mech to be in at that position. Works a treat.
Anybody else recently done a 1x9/10 set up?
Would be nice to see.
Posted : 17/01/2012 11:37 am
You will definitely, definitely need to put a chain device on there.
Posted : 17/01/2012 11:40 am
I don't if the chain stays on.
Posted : 17/01/2012 11:41 am
I finished my 1x9 late last year, its been great, but has recently started dropping its chain for no good reason, so had a spare front mech, slapped that on and its now been fine, thinking about just sticking the shifter, cable and granny ring on though.
Did this recently with a 36tooth front ring and 32 max back. Not tried without a chain device, tbh. I've been riding singlespeed a lot recently so it doesn't feel too bad climbing...
Posted : 17/01/2012 11:42 am
That chain WILL come off.....
Posted : 17/01/2012 11:44 am
As we are all showing off here is my 1x9 its been like this for about a year now and my previous bike was 1x9 too. Infact I was on 1x8 back in the day when I could jump.
I need a full chain device as my chain was all over the place with just a bodged front derailleur. I think FS bikes are more in need of a chain device because the back wheel moves around causing chain growth/shrinkage issues.
[url= http://farm7.staticflickr.com/6188/6082188422_00339d07fb_o.jp g" target="_blank">http://farm7.staticflickr.com/6188/6082188422_00339d07fb_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/29930426@N04/6082188422/ ]P1000890[/url] by [url= http://www.flickr.com/people/29930426@N04/ ]i_ache[/url], on Flickr
[url= http://farm4.staticflickr.com/3136/5838825181_b2ec6eb281_o.jp g" target="_blank">http://farm4.staticflickr.com/3136/5838825181_b2ec6eb281_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/29930426@N04/5838825181/ ]IMG_0021[/url] by [url= http://www.flickr.com/people/29930426@N04/ ]i_ache[/url], on Flickr
Posted : 17/01/2012 11:52 am
I_ache - the drainage on your lawn needs sorting out.
Posted : 17/01/2012 11:53 am
I run a 34 front (Middleburn SS ring) and a 11-34 cassette and for a long while didn't bother with any retention and had no issues whatsoever. I've notw stuck a BB mounted Superstar top guide on, as one of my friends with a similar set up on his Felt was having issues and I still have no problems. I think the difference is that my chainring is SS specific so has no ramps or pins on the teeth and therefore when the chain is angled from top or bottom of the block and also slapping around a bit there's no "help" for it to jump off.
Posted : 17/01/2012 12:00 pm
Posted : 17/01/2012 12:20 pm
wwaswas Thats my fish pond.
Posted : 17/01/2012 12:24 pm
If you indeed find you need a chain device, something cheap can work - go for a Jump Stop and BBG bashguard, perhaps.
Posted : 17/01/2012 12:27 pm
Mine. Has a chain device on now, this was just taken before I rode to get some lunch when I'd just finished it and wanted to check the chainline etc before putting the guide on.
Posted : 17/01/2012 12:44 pm
There is nothing more guarantee'ed that the chain will come off when you are putting most power on your cranks, a poodle around a lake is no test.
I hope your A&E/Dentist is close by.
Posted : 17/01/2012 2:00 pm
back in the day i ran 1x7 for about 18 months with no chain device, never had a chain issue at all.
although, i will say, in those days there were no ramps/ cutaways on the ring to help shifting.
ive been running 1x9 for a few months now on a hardtail with no chain device, no issues at all (new slx 32t ring)
havent ridden this one off road though.
its not gauranteed to come off.
it might do, it might not.
Posted : 17/01/2012 2:21 pm
I use Jump Stop and bashguard. A fancy chain device wont protect the underside your chainring
Posted : 17/01/2012 2:22 pm
My fancy chain device does. The bash guard is included. E:13 LG!+ guards have a bash plate that bolts to the back plate that will protect your chainring too.
Posted : 17/01/2012 2:28 pm
I'd definitely get a guide on there. £15 for a Superstar one, and if it goes as you put the power down it could be very unpleasnt indeed!
Here's my 1x10
Posted : 17/01/2012 2:38 pm
I didn't take the bike for 'a poodle around a lake' as you put it! It was a mix of road/path and forest plus a set of steps (as I said) something I normally dont ride on my route, to test the chain.
Thanks for your concern though about my safety.
I did have a e13 XCX chain device (BB mounted) but could not get alignment right with it so decided not to use it.
Went to get a Pauls Device but as there in the states they where out of stock so am awaiting one of them.
But I do know that at the moment, its stays on, even when pushed with 'a poodle around a lake'. 😉 hahaha
Posted : 17/01/2012 3:38 pm
Jesus njee Ive just been sick a bit in my mouth lol
Posted : 17/01/2012 5:16 pm
Aye, but it's fast!
Posted : 17/01/2012 5:18 pm
njee, couldn't quite place it, is it a Trek?
Posted : 17/01/2012 5:20 pm
Some sort of active camouflage going on there? Nice tho.
Quite fancy doing this for some weight saving but would prob need to start with 2 rings on the frOnt due to my chronic lack of fitness!!
Posted : 17/01/2012 5:34 pm
Posted : 17/01/2012 5:38 pm
Not sure to be honest, never looked closely enough!
I'd run doubles for years prior to going for a 1x10, and probably still would on a less 'racey' bike. Chuff all weight saving doing that, but it can give more usable ratios if (like me) you find 22t too small, and 44t too big. I run a 36t with 11-36, if anything I'd have slightly more top end for the road, but I'm not man enough for a 38t ring!
Posted : 17/01/2012 5:41 pm
Here's mine,
I'm running a 32t un-ramped RF ring with a M-Part XC BB guide and a 12-36 cassette out back. Pretty much fine for everything bar really steep climbs.
Posted : 17/01/2012 5:54 pm
