Hi,
So I made a press and pushed everything back in, no problems. However tonight there was a bit of a clicking sound from the BB and when I’ve looked the cup has moved out again.
Will applying loctite to the cup before pressing it back in and if so which one?
Also, can anyone one enlighten me as to what kind of bottom bracket this is? The bike is a Cannondale F29 and the spec sheet specified ‘FSA BB30 w/Wheels Mfg adapter’. Having googled a bit it seems its not actually a BB30 as I had assumed. The bearings are in a plastic sleeve and there are no circlips involved. Also the mentioned adapter seems to work differently ie goes into the already installed bearings.
What I have looks like a HT2 BB without the treads on the cups.
Sorry for the numpty question but I’d like to know what I need to buy if I have to replace.
Cheers,
Rob
Edit: should add im using HT2 cranks if it matters.
