Fast, tough, light ...
[Closed] Fast, tough, light summer tyres
[#1640616]
Any recommendations for a rear 2.1" tyre? Currently have a crossmark which I love but ripped the sidewall.
Posted : 25/05/2010 10:05 am
Maxxis Aspen.
Posted : 25/05/2010 10:08 am
Racing Ralph or Furious Fred depending on how brave you are/how light you want to go.
Kenda Small Block 8
Posted : 25/05/2010 10:10 am
Intense System 2's are pretty good. Come up fairly narrow, though.
Michelin XC Dry2. 2.0 but come up a little larger. Tough, light(ish) and fast rolling. Oh and cheap!
Posted : 25/05/2010 10:11 am
I'd have said SMB8 but I've got a feeling the Maxxis is tougher... I'd also wager the Schwalbes will be more delicate too.
If you love the Crossmark, give it another punt and hope it was just bad luck. Sometimes it just happens - I've gone two years on Kendas without a single tear and then ripped 3 in one month! But been fine since so go figure!
Posted : 25/05/2010 10:13 am
 br
I run a Maxxis Larsen 2.35 (650g) which works well, and seems quite strong against the flints around here - but a riding buddy on Sunday had the 2.1 version 'hole' with a sharp piece of flint.
Posted : 25/05/2010 10:31 am
[url= http://www.starbike.com/php/product_info.php?lang=en&pid=9797 ]Furious Fred 2.25" with Raceguard[/url]. Sensible price, 435g and you won't find a faster tyre!
Just don't try to go round corners 🙂
Posted : 25/05/2010 10:37 am
I do like maxxis tyres and was thinking about the larson. Is the exception casing the ultra thin one?
Posted : 25/05/2010 11:08 am
Shame they don't do a tubeless version of the Larsen 2.35 - my fave tyre at the mo.
http://www.chainreactioncycles.com/Models.aspx?ModelID=48399
Cheeap!
Posted : 25/05/2010 11:18 am
Just checked those Larsens on the CRC link; love the simple pleasure of hovering over the tread pattern for a close up view. It's entirely gratuitous.
Love it!
Posted : 25/05/2010 11:34 am
I run a rear Larsen, works well, but spins out quickly on slippy hard surfaces as you might expect. For example, barely damp roots, or with a wet tyre exiting a stream, trying to climb out on a bedrock surface.
That's my back tyre experience from my last bike ride anyhow!
Posted : 25/05/2010 11:43 am
 sem
Conti Race King. Surprisingly fast, grippy and slow to wear. I expect a lot of that is from my choice for the super sonic because I have a bit of a thing for the black chili compound coming out of their German factory :o.
http://www.chainreactioncycles.com/Models.aspx?ModelID=30228
Posted : 25/05/2010 11:49 am
I have a set of Conti Speed king protection available? Super light and fast, 2.3 for the front and 2.1 rear, the 2.3 is very narrow though. Mail me if you are interested. 😀
Posted : 25/05/2010 12:00 pm
 br
[i]Shame they don't do a tubeless version of the Larsen 2.35 - my fave tyre at the mo.[/i]
I'm just running the normal one, tubeless on an 819 rim with latex. Do find that I can't run it at the low pressures I normally use as there is a lot of squirm - probably just a bit wide for the rim.
Posted : 25/05/2010 12:02 pm
Spesh Fast Traks.
[i]slippery roots[/i] ? [i]low pressures[/i] ?
C'mon guys we're talking SUMMER 🙂
Posted : 25/05/2010 12:12 pm
The Racing Raphs are very good but Afan's rocks brutalised the sidewalls! If you dont ride anything to extreme to often though they are brilliant.
Posted : 25/05/2010 12:14 pm
Or get the Double Defence or RaceGuard version.
Posted : 25/05/2010 12:21 pm
SB8's. All you need.
Posted : 25/05/2010 12:29 pm
Which has the tougher casing SB8 or Maxxis Larson/crossmark?
Posted : 25/05/2010 12:44 pm
Slight Hack - Which ones for the Kielder 100?
Posted : 25/05/2010 12:47 pm
Keith Bontrager: "pick any two".
LUST Crossmark has thicker sidewalls and you'll save the weight of rimstrip.
Recent thread on here stating that tyre weight is a bit of an irrelevance off road.
Posted : 25/05/2010 12:50 pm
Dunno how much grip they'll provide for others being a bit faster, but the Continental Race King 2.1 worked surprisingly well for me on the rear - didn't slip much on the roots at Wharncliffe last summer.
Posted : 25/05/2010 12:51 pm
