- This topic has 176 replies, 62 voices, and was last updated 12 years ago by Woody.
FAO doubters
iDaveFree Member
Can I ask what was wrong with well set up ‘non-spoon’ v-brakes?
DobboFull MemberReminds me a bit of the badger thread. Just need bez to do a few photo-shopped pics, and Al to threaten to take take TJ to court.
simondbarnesFull MemberCan I ask what was wrong with well set up ‘non-spoon’ v-brakes?
They don’t work with sti levers
KucoFull MemberThe forces that go through a disc brake can crack/snap welded even casted mounts and yet you thought some what looks like badly applied epoxy would hold it? Also did you allow enough time for the epoxy to cure fully before trying it?
7hzFree MemberIt broke very quickly, coming to a brief stop. As Bloblo guess the cf parted from the ti so it was the gluing that was the weak point. I’m gonna try it again with proper glue, just to see
It is not only the bonding that is the weak point, the design places all the stress onto the bonding in a way that will guarantee it will fail.
Listen to everyone, they are right.
You need a brace coming straight down 90 degrees from the top nut to stop it being pushed toward the seatstay. Ideally, this would be in the form of a triangular piece welded to the seatstay (look at any other brake mounts on seatstays for ideas).
Unless it is welded on, I wouldn’t trust it as far as I could throw it.
The thing is with this, if you manage to bodge it so it can resist a 5mph stop on a flat road, what is going to happen is it’ll break when you are doing 30mph down a hill, and a car / person / hedge appears in front of you.
A bike is a very minimalist structure that needs properly designed and built to resist the forces applied to it. If it is not properly designed and built, it will fail and you will crash and hurt yourself.
So have a flippin word wi yersel, and drop this stupid idea.
molgripsFree MemberYou did video it! What a sport 🙂
Don’t let TJ piss you off btw. There’s no need for agro even if your bodge isn’t trailworthy. You wouldn’t want to spend your last hours alive (you weren’t wearing a helmet 😉 ) arguing with TJ, that’d be a shame.
I still think Toys is right, you just need to make the bit triangular (the short side will stop it rotating) and then attach it to the frame. Jubilee clips will work because they’ll provide friction, but you’d be better off using the V brake mount. Which means you might as well just buy or copy one of the existing designs.
thebunkFull MemberCan you give the lawyer crap a rest guys? It’s really really boring.
Keep going al – I don’t reckon it will take much to get it to work.
Though I do think you need something better than glue, and another (spoon) brace…
DancakeFree MemberCan I ask what was wrong with well set up ‘non-spoon’ v-brakes?
They don’t work with sti leversisnt there something called a ‘travel agent’ or some such thing?
cynic-alFree MemberKuco – 48 hours or so?
iDave – discs offer real advantages over rims brakes for me.
TandemJeremy – Member
really al.Do you not understand the basics of how a bolt works? clearly not. Yo put tension on a bolt. This clamps the two pieces together and creates friction between the two pieces. Its the friction that resist movement not the strength of the bolt. If it was merely the bolt it would always fret as there is a clearance in the hole
Your setup you have rotational loadings on the bolts
That statement about lawyers is correct in the context of the thread.
You know better that the OED do you.
really Jeremy.Of course I understand it. If the friction is insufficient to stop the part moving, as you seem to suggest, it will move, and then the shear strength of the bolt omes into play.
In any event I made sure the plate was rotated as far as possible in teh direction it wants to rotate under braking forces before I tightened the bolts up – or I should say nyloc nuts.I meant to imply that I accepted the OED – I have no idea how you mis-interpreted that.
Sorry but your statement was bollocks – many private practice solicitors appear in employment tribunals for both sides.
cynic-alFree Memberthebunk – Member
Can you give the lawyer crap a rest guys? It’s really really boring.molgrips – Member
Don’t let TJ piss you off btw.It’s 100% fun here 😛
toys19Free MemberIf the friction is insufficient to stop the part moving, as you seem to suggest, it will move, and then the shear strength of the bolt comes into play.
exactly, except you realise that the shear strength of the bolt will not help you if you are trying to stop rotation..
bobloFree MemberI like the crows in the vid sounding sad cos they didn’t get any dead meat 🙂
Epoxy will not bond properly to curved, shiney Ti. You’ll need to flatten and key the surfaces to get a decent bond and this probably (certainly) won’t be enough to stop the shear that is induced by the rotating brake caliper. Doing this will also certainly fubar the seat stay.
The brake caliper will, at some point, rotate around the mounting bolt as you only have the tightness of the bolt to stop it (friction). If you carry on tightening the bolt to stop the caliper rotating, you’ll reach it’s elastic limit and it’ll snap. You might get lucky by using higher grade bolts (e.g. 8.8 and above) but I wouldn’t bet the crows dinner on it 🙂
TiRedFull MemberOf course it broke; the CF epoxy joint could not resist the thrust forces from the rotation of the brake calipers. I wasn’t having a joke with a P clip – I have far more faith in that solution than the rough epoxy joint you made. It will work, but I wouldn’t trust it long-term. Prove me wrong. Your problem is really that you have no effective means (short of welding) to resist the thrust along the short tangential bar. Make a longer one and fix it to the existing brake bosses (assuming you didn’t grind them off). Or go and buy an adjustable tie rod for the purpose,as already mentioned. That is the solution listed in most of the examples on the the thread I linked to – commercial and otherwise.
PS, I hope the expoxy comes off nicely, and get some 3M Scotchpad to clean up the mess you’ve made.
cynic-alFree Membertoys19 – Member
exactly, except you realise that the shear strength of the bolt will not help you if you are trying to stop rotation..Eh? There are 2 bolts attaching the lower mount, which is what I am talking about.
Thansk for your concern dj, but I’ve know about the Scotch 3M thing for decades.
mightymarmiteFree MemberPlaying adjudicator here re employment tribunals … you’re both right 🙂
Lawyers wont get out of bed for £££, and typically their £££ are so high that their fees are met by an award made by the courts as part of the settlement (hence the rampant no win no fee culture).
Given that the employment tribunal was set up with the intention of being a mediation service as a last resort they don’t award costs (including legal fees) etc. Guess the intention is to keep is simple, and accessible to all (and less threatening and complicated).
Hence any solicitors / barristers that are retained are done so out of the pocket of the individual, and as any pecuniary awards are typically pre-set makes the cost / benefit argument of using a solicitor / barrister less effective. Hence they are a rarity.
In larger case trails, or larger collective suites then yes, they do warrant their inclusion. The majority of companies (mine included) also retain legal insurance (Mentor Services in my case) so when involved do have legal representation, although typically are not necessarily members of the bar nor solicitors (as was my case).
Some household policies do now also include legal representation for employment tribunals so there are a few more about (but again not necessarily solicitors / barristers).
In fact in a lot of instances if you rock up with a solicitor in tow, the adjudicating panel (made up of both a judge as well as representatives from a trade union and business organisation) will frown upon it as it goes against the intention of the tribunal.
So to paraphrase, they do appear in the employment tribunals, but not very often and rarely on the behalf of the claimant.
Now … ding ding round two.
bobloFree MemberCA, yes it has 2 but unfortunately you’ve designed the lower one as a pivot…
BTW Employment tribunals was another much duller thread. This is DIY engineering please stop polluting it with Lawyerly guff 🙂
JunkyardFree Memberso to paraphrase as i dont need to spend my lunch reading al v TJ part Yawn] I assume it broke very quickly when you first braked
You are clive sinclair and I claim my useless underpowered electrical vehiclescaredypantsFull MemberI’m sure it came up in the earlier thread(s), but that frame looks like it might take an A2Z adaptor – have you tried it to see, al ?
bobloFree MemberSorry to say, this is bang on:
The lower bolt (red x) is the pivot as there’s nothing between the top bolt and the stay to stop the ‘spoon’ from closing on the stay. As it does this, the Spoon anchor point (black scab) travels up the stay delaminating the epoxy bond. Hard to describe, hope this makes sense.
<edit> can’t get my plagiarised photo to show but it’s TJ’s phot below.
TandemJeremyFree MemberIndeed al – look at your picture that I modified and posted. The bolt marked with a red cross will act as a pivot and the calliper will rotate towards the seatstay –
If you are adamant about continuing with this I suggest you listen to what folk are saying.
You want positivity? You didn’t listen to any of the advice you were given previously but try this
What you need is a single plate bolted to both calliper mountings, both bolt holes in teh drop-out and preferably to the axle as well IMO and to the seatstay. If you want to glue it ( and I don’t understand why not use the v brake mount) then you need the area to be glued to match the curve of the seat stay
something like this
Image1 by TandemJeremy, on Flickr
Then the glued area will only be in compression (ignoring flex in the plate) and you will have a large area glued that might holdMister-PFree MemberCan I ask what was wrong with well set up ‘non-spoon’ v-brakes?
Nope but a set of mini-vees would.
cynic-alFree MemberOK ta boblo, gotcha.
No-one actually knew whether the epoxy would hold it – and what I was seeking to do in the last thread is exactly what you have proposed BTW (and I have tried that without glue and it works fine) – and you said it wouldn’t work on that thread.
So in effect I was right in the last thread and you were wrong, which your post above now concedes.
THREAD CLOSED.
simondbarnesFull MemberNope but a set of mini-vees would.
Yeah, but they’re awful things IME.
j_meFree MemberBetter. Whatever you do shirley the weld at the bottom of the seat stay would be a weak point as it will be taking loads it hasn’t been designed for
TandemJeremyFree MemberNo al – what you proposed is not what I have drawn- the critical difference is that I suggest the glued mount should be semicircular wrapped around the seatstay to give a large area of coverage and it still has large doubts about it – that it will be loading stresses into the frame that it was not designed for – some frames have a brace between the seatstay and chainstay to spread these forces and also that the two mounting bolts are m5 and were not designed to take the level of force that you will be putting in them. I also suggest ( as I did before) using the axle as one mount
I knwew it would be a waste of my time trying to help as for reasons of your own if I say it you think it must be garbage and you never actually take a moment to think about it before dismissing it out of hand
bobloFree Memberj_me – Member
Better. Whatever you do shirley the weld at the bottom of the seat stay would be a weak point as it will be taking loads it hasn’t been designed forYes, ultimately, that would be my concern. If the epoxy did hold or if you redesigned the support as a triangle to stop the rotation, you’d then be inducing a bending moment into the lower part of the stay.
I’m no frame designer but that stay is not designed to take the induced load and is pretty thin there. I wouldn’t be surprised if it would result in a bent or badly dinged stay. With the present set up, that’s not a concern as the epoxy will fail at low loads saving the stay from any grief.
Have a go at copying (or buying) the commercial one that picks up the canti boss. That’s been properly engineered and the canti boss (and surrounding stay) is designed to take the loads you’ll be introducing. It would be a shame to knacker a nice frame unless it’s disposable to you.
JunkyardFree MemberNo-one actually knew whether the epoxy would hold it
I told you it would not hold it you got shitty as you did not want to listen/hear anything critical 🙄
WoodyFree MemberThis is brilliant,
We have legal eagle/expert engineer and mechanic Al being slated by NHS/health related desk jockey/renowned multi-discipline expert TJ who is trying to tell these guys
The funny thing is everyone in the room (2 x phds, me an MSC and a recent grad)
where, why and how the engineering is flawed.
Absolutely brilliant 😆
mancjonFree MemberAnd it’s just as funny that if Al and TJ actually listened to each other between them they may well be able to come up with something that worked.
As it is, if one says do this the other one decides to do the opposite. Eventually Al will end up with the design originally suggested by TJ by which time TJ will be arguing for Al’s original design.
TandemJeremyFree MemberWoody – apart from toys and I were in agreement about the actual engineering. 🙂 Just he was trying to put a positive gloss on it and I was not.
bobloFree MemberCue ‘Our Tune’ theme…..
Love and Hate are such close emotions… I’m expecting them to elope soon and never to be seen again…
DracFull MemberCan I ask what was wrong with well set up ‘non-spoon’ v-brakes?
They don’t match the forks. 😆
7hzFree MemberHave TJ and Cynic-al ever met?
You guys are both in or around E/burgh, right?
7hzFree Membercynic-al – trying to even defend that gluing on brake brackets is a good idea is just plain stupid mate. Don’t know why others are kidd gloving this, you are a bam for even trying it!
TandemJeremyFree Member7hz -yes. We used to be friends until al decided to continually make personal attacks on me and refused to stop when asked.
thebunkFull MemberI refuse to believe that either of them exist. They can’t be real people, surely…
TandemJeremyFree MemberI will also say that Al is a decent bloke in the flesh – like many of us becomes a complete male chicken behind a keyboard
The topic ‘FAO doubters’ is closed to new replies.
