Out of curiosity, why didn't you go for glazing the full window panel (like on factory combis/minibuses)?
Personally, because Seitz are double glazed, bigger opening, integral blackout blind and flyscreen, and much easier to make good on the inside. Bring ply lining up to a bonded window is much more fiddly to do neatly. Also in my case, the bonded windows were too low so would go below the height of the seat backrest, worktops etc. Not such an issue in fwd vans with a lower internal floor.
What spooky said -- bonded windows look good on the outside, but the actual aperture isn't all that large and you don't get much of an opening. Also they're single-glazed glass, which is heavy and not that well insulated. And you'd have to make blinds/curtains for the inside, while the Seitz ones have integrated blinds/flyscreens.
Costs: Original estimate was £5k, more likely to be £6k-ish. As others have said, it's a few big-ticket items plus millions of sundries that you don't really allow for 😉 Had a few ebay/used bargains (seats, water heater, toilet, roll-out awning) but a lot of bits are new. The cheapest approach is to get a donor caravan and use everything out of it -- the SBMCC reckon that £3k is about the baseline cost for something worthwhile.
I'm thinking of putting a password on this thread because if Madame sees "Mike-D" she will look in here. The vague idea of another "Wendy house on wheels" will then be added to my list of things to do. I'm safe for a few more weeks thanks to a carpal tunnel op'. Anyone got any ideas for something to do on a rainy day with just one hand?
Great project. I'm very envious but can't do anything like that here (Spain) as it's almost impossible to change a vehicle from original spec. The easiest way around is to build everything removable for the biannual "mot" ; you actually see people pulling out all the woodwork in the testing station carpark.
Mike can I ask what your background is? I'm reasonably handy but don't think I would have the confidence to cut holes in the van/ fix the seats in etc
Mike_D - MemberThe cheapest approach is to get a donor caravan and use everything out of it
Be warned, my neighbour did this, he ended up becoming a caravenner instead. We more or less had to take a half dismantled Convoy off his driveway with brushes and shovels. Then the original donor van turned out (unsurprisingly) to be rotten so he bought another one. Then he replaced his car so he could pull it better.
Well done , I'm rather enveious
I had a master lwb high top as my daily drive for two years while I failed to build it into a proper camper
I just never made my mind up on the layout so never started more than a very basic kitchen unit and fold out bed
lastuphills: I work at a desk typing stuff. But I've done a fair bit of house DIY and have a decent selection of tools. A lot of van stuff is regular carpentry/wiring/plumbing, it's only the metal stuff that's novel. The hole in the side you see above was the first hole I'd cut in a motor vehicle, unless you count bodging up rust holes in my old Escort 😉 There are plenty of resources on the net to point you in the right direction. None of it's that hard, but it is time consuming. The aforementioned Self Build Motorcaravan Club (www.sbmcc.org.uk) is a good place to start - £15 membership but you'll save that the first time you buy anything 🙂
Always do your first window in the sliding door...it may be a pain but you can always get a whole replacement door if you royally f-it up!
Its a simple process of measure 43 times, cut once. And don't be tempted to cut too tight as its a real pain trying to trim a few mm from a wobbly panel - didn't make the same mistake on the other windows! 🙂
Wise words 🙂
Having done all that on the sides, it was time to climb up on top and repeat the process for the rooflights. Nearly made a catastrophic blunder because I had the dimensions for the two big side windows stuck in my head -- the y dimension is the same as for the big rooflight, but the x is different. Managed to notice before I cut a hole 200mm too wide in the roof... Marked out the right size:
The instructions call for a 12mm radius at the corners, I deemed 12.5mm from a 25mm holesaw to be close enough. Also the holesaw matches the van, which is nice:
Then join the corners with the jigsaw. It's a bit awkward across the roof because it's corrugated:
Look out below!:
Lets a bit more light in. You'll also notice some floor insulation going in:
Timber frame as per the side windows. Yes, it had got dark by this time, and a bit cold -- not ideal conditions for Sikaflex to cure, but it seemed to work:
After a night with nothing but a sheet of thick polythene and some gaffer tape to keep the weather out, the rooflight went in:
Not pictured is the almighty faff filling in all the corrugations to give the rooflight an effectively flat surface to sit on and seal against. After a couple of failed (ie leaky) attempts, success was found with pieces of rigid PVC from a building plastics place cut to fit the shape of the hollows and bedded on Sikaflex. Two layers of mastic-on-a-roll between that and the window seems to have done the trick.
Then repeat for the smaller rooflight over the bunks towards the back:
And if anyone's wondering what the lifespan of a cheap 25mm holesaw from Screwfix is, it's about eight holes. OK, seven, the eighth one was a bit slow:
As if two rooflights isn't enough, there's a third one going over the washroom. Partially for ventilation, partially for light, partially so I can actually stand up in the shower -- the shower tray is a little higher than the floor and while the headroom is adequate in the rest of the van, a little more bonce space will be useful in the washroom. So the end result is this:
Third week of January and it looks quite a lot like a camper. On the outside, at least... Around this time the original double passenger seat came out:
New single seat base (sourced for a company called Cabmasters oop north, if anyone ever needs a single Ducato passenger seat...):
And the seat itself:
Had to work a little bodge with the seatbelt tensioners -- the double seat has two, the single has (naturally enough) one. However, the van electrickery expects there to be two and puts the airbag warning light on if there's only one. Apparently you can't persuade it otherwise by plugging in a laptop or anything, so I spoofed it with a 3.3ohm resistor across the cable to the missing connector.
While the double seat might have been occasionally useful, it wasn't the best seat -- it's fixed, with no adjustment of anything, and was set well back so it intruded into the accommodation space quite a lot. The single is much better, and leaves a nice big gap through which we can clamber into the back.
Looking very nice indeed!
So, fitting seats then. Quite a minefield, and there are an awful lot of hideous bodges out there. After lots of research, I found a handy VOSA document about minibus safety which had specs for bolted-in rear seats. Seats with built-in seatbelts have to be more strongly attached than thos with separate belts, because all the seatbelt loads are going through the seat mounts. If the seatbelt is separate then the seat mounts only have to hang on to the seat rather than having to deal with an occupant as well. Integrated belts are a lot easier, though, because you don't have to find somewhere to attach the belts to. The Ducato has provision for a belt on the offside C pillar, but inevitably it's not quite in the right place for where we want our seats and we need two belts anyway.
As previously mentioned, we sourced a pair of second-hand minibus seats. The VOSA spec calls for M10 8.8 grade bolts and minimum 75x75x4mm spreader plates, under the floor for the rear bolts and above the floor for the front ones -- if you decelerate suddenly, the seat's trying to pull itself out of the floor at the back and punch through it at the front.
First I had to work out where the bolts could go. Fortunately the legs can be shuffled sideways on the seats, because there's an awful lot of stuff to miss under the van:
All those hatched areas (well, most of them -- some are in the wrong place :roll:) represent hollow chassis rails. No point drilling there, you won't be able to get a nut on the other end of the bolt.
Having identified places for the bolts to go, I shaped the front spreader plates a bit so they sit flat to the floor between corrugations. The plates were made up by a local fabricator from a usefully-sized offcut -- they're actually 6mm thick but this is one area where I don't mind a bit of overspeccing. They're also big enough that I'm comfortable with lopping the corners off with an angle grinder:
so that they fit snugly like so:
And yes, that's the driveway you can see through there. Repeat where necessary (a couple of them went in unmodified) and bolt the legs in:
The rear bolts have plates underneath:
That's the handbrake linkage in the foreground, one of not many things under the van -- it's front wheel drive, the exhaust comes out behind the driver's door so between the transverse silencer and the back axle there's nowt other than the handbrake linkage and some brake pipes and wires at the edges. This will come in handy later.
With the legs securely mounted, the actual seat frames can go on:
And the bottom cushions:
Handily, the cushions are held on with a single handwheel bolt under the front edge. The bench seat will be at the same height as these so everyone's sitting level, the travel seat bottom cushions can be quickly removed so the bed can pull out over the seat bases.
View looking forward:
To give an idea of scale, the area behind the rear seats is as long as the entire interior of our old T4. Even with the seats in, it still took 8x4 sheets for a while, until the rear bulkhead went in...
Bravo!
There looks like acres of space between the back seats and the front. Is that going to be a double bed?
Yup, the bed makes up to 186cm long (basically the full width of the van) and 130cm wide, so 10cm narrower than a standard double. More importantly, 20cm wider than the bed in our previous van 🙂 The rear-facing bench is also split so you can pull out the bit by the sliding door by itself to make an L-shaped seat so you can sit six (comfortably) or seven (at a push) around the table. Or two people can both sit on it with their feet up 😉
The compromise is that the gap between rear seats and rear-facing bench comes out quite small, so if two adults sit opposite one another their feet end up overlapping. But there's enough room that knees don't collide, so that's OK.
Enjoying reading about this....keep up the cracking work, looks a great project.
I ruddy love this.
GOt my keen eye on a hi top LWB vivaro....
DrP
Small tip - maybe useful maybe not - about wot someone said earlier -if you fit LPG tank you cant use le shuttle. Fit refillable LPG tank (gaslow etc) and you can.
Eurotunnel is fine with fixed tanks up to 93l as long as they're for powering cookers and stuff rather than actually fuelling the vehicle. We're using an underslung 38l tank.
C'mon Mike ....... more photos of the conversion process pls
Go on then, a few more for lunchtime 🙂
While we're discussing LPG tanks, here's one:
It's a vapour take-off tank, so not the same as the sort that LPG-fuelled cars use. In theory you can get this size with welded-on mounting lugs, but they were proving hard to get hold of at the time, so this is a regular one. Needs a coat of underbody paint before carting it around under a van:
Then bolt the mounting frame to the underside:
The tank's held on with steel straps. As standard, the frame comes with two, but that arrangement's intended for putting in a boot with the tank on top of the frame -- the straps just need to stop it moving. If it's actually hanging, the supplier recommends a second pair of straps. They're a right faff to fit, being adjustable for length by threading them through a buckle/bracket thing. Just like you might use for holding a tent to a bike rack, except made of steel :/ Also there's not much room around it. Eventually, though:
Getting it up there was entertaining, involving a trolley jack, various bits of wood, and swearing. It sits up out of harm's way between the chassis rails -- the thing in the foreground is the exhaust silencer, the tank is higher than that and higher than the fuel tank, so should be OK.
Also under the van are the fresh and waste water tanks, shown here not under the van:
Before fitting, I had to make holes:
To fit the sender for the level gauge (an actual gauge for fresh, just a full-up warning for the waste):
Then fill the hole with a screw-in hatch from the boat shop:
They go up under the van too -- they're specifically made for these vans, so fit neatly around the various bits of chassis. They're supported by steel cradles hanging off J-bolts through holes in the chassis rails:
What else? Bought a big pile of insulation:
25mm for the floor, 40mm for the ceiling, 50mm for the walls. Cosy 🙂 Here's the insulated floor:
Then the ply can go back down and we can mock up the washroom:
and mark out where the kitchen's going:
Around this time we also fitted a cheap ebay reversing camera:
It's a fairly mad wide angle, you can actually see the top corners of the van in the screen, which is stuck to the windscreen pretending to be a mirror:
Yes, the camera needs adjusting so the picture's actually level. Also it distorts quite a lot at the edges, my guttering's not that bad... Camera and screen are hooked into a spare switched live in the fusebox, so they're on all the time the ignition's on. You could piggyback off the reversing lights so they're only on when reversing, but I decided it's handy to be able to see behind when driving.
[img]
Vehicle electrics scare me
Fortunately I don't need to mess with them too much. Camera feed just involved sticking a spade connector into the front of the fusebox (where a fuse would normally go) and adding an in-line fuse holder to the wire. Then earth the -ve wire to a handy bit of bodywork. We'll gloss over the malfunctioning bypass relay in the towbar wiring that allows everything to work except one indicator -- it's currently unplugged pending further investigation.
Best thread ever... Its like being in an episode of The A-Team. Keep up the good work and posting pictures
dux - Member
Best thread ever..
+1,000,000,000
Wish I had the tools, skills, know-how and time to do something just like this
C'mon Mike, we're waiting for the next installment!
More coming when I get home to a proper computer 🙂
Time is the hard one. All the rest can be acquired as you go along 😉
+1 on the great project, I love threads like this!
Spain - it doesn't look that complicated to pass the ITV (Spanish MOT) with a modified van, just (potentially) expensive and tedious.
... but the removing bits before heading to the ITV(MOT) is pretty common, I've seen it loads with motorbikes 🙂
Thinking laterally, does it have to be original factory spec, or spec when registered in Spain? Could you get someone in France to modify a van then register it across the border once done?
No - after 6 months you have to register the car in Spain, and at that point you have to pass the test - and that means having various bits of paperwork in order...
Not sure how they could tell if your car has been in Spain more than 6 months, though.
Edit: applies to vans / motorhomes, too!
Great thread, really interesting to read.
Mike, I like the way you make everything sound so easy. "yeah cut a hole over here ... put a bolt in there ... done!" 🙂
Glad I found this thread, have wondered about a conversion in the past, this is great inspiration!
jairaj: I'm skipping the parts about the hours of research, thinking, scribbling, measuring and staring at things with a mug of tea in hand because it's not that interesting 😉
Apologies for tardiness of updating, have been out and about and pesky Actual Paid Work keeps getting in the way. Will have more very soon, stay tuned 🙂
Right, finally, here we are again. This is, er, early March sometime, maybe. A while back, anyway. Van still capable of carrying big piles of Celotex:
Which gradually got cut up and stuck to the sides:
We used expanding PU foam out of a gun to stick it up, much more controllable than the aerosol stuff and you can also not use it for a few days and come back to it rather than having half a can you just have to chuck away.
Next up, the toilet. Got a second-hand cassette toilet out of a caravan, which I must say was impressively clean. Which is good, because the waste tank came out of the wrong side and had to be reversed by taking out various spouts and putting them back in each other's holes:
Then position the loo against a mocked-up wall to see where the hatch needs to be:
Although there aren't many options due to the structure of the van -- it has to go exactly here:
So actually the exact position of the loo is governed by the location of the hatch rather than the other way around. The loo has to be raised off the floor slightly to avoid the hatch going through the actual sill. Pull the plastic panel off the outside (the hatch will slightly overlap this):
Then it's pretty much like doing a window. Pilot hole from the inside so you can see where you are and mark out from there:
Holesaw, jigsaw, you know the score:
And from the inside -- not much margin for error (strayed slightly onto a double-skinned bit, but not a problem):
Offer up the door:
The waste tank can then be extracted from the van like so:
Added a timber frame on the inside to give the screws something to hold on to. The various awkward shapes meant some rather fascinating bits of wood:
You may be thinking that a slightly tatty, off-white door in a blue van is going to look a bit rubbish. And you'd be right. Fortunately you can take the door apart and remove the panel. Dig out a bit of handy blue-painted steel from a previous window hole:
Draw around the white bit and cut out:
Get some plastic primer and suitable paint and spray up the frame and surround:
Put it all back together again:
And put in the side of the van:
To finish off, seal around the edge with Sikaflex, trim a bit off the top edge of the exterior trim panel and put that back on. BOSH:
That was one of the last substantial holes in the side of the van. But not the very last...
Adds Mike_D to the list of folk on here who make me feel inadequate 😡
We had one of those vans bought already converted into a horsebox.
Quick too and when empty you could easily do 80mph and overtake folk on A-roads 🙂 Plus even loaded (and with a sleeper/hi-bay above the cab) would manage +30mpg happily.
Great thread, looks like another thing on my list of things I want but have no time/money/need for!
Love this thread!
Loving it too! More updates needed please...
Just moving to the front page so we don't have to trawl back to far.
Damn you Wingnuts; thought it was a new installment!
Hi all! Have some plumbing. Well, of sorts. A few updates back a fresh water tank found its way under the van. Not a lot of use unless you can get water in it, so a filler had to go in. Unleash the hole saw:
Make a hole:
(That bit had already been insulated, but it doesn't matter -- just drill straight through). Filler cap goes in the hole like so:
That gets the water inside the van, but we don't (we really, really don't) want it there, so another (slightly smaller) hole underneath:
It's under the rear seats in a position that's a compromise between the pipe not having to dip under any chassis rails and not forcing any too-extreme bends in it. Pipe runs under the van and in like this:
Up through the floor:
And connects to the back of the filler:
Ah. B*gger. Well, you get the idea -- had to get a slightly longer bit of hose to finish it properly 🙂
Around this time the water heater went in. Bit of a luxury this, but we had one in our previous van and kind of got used to it, so we're having one in this too. It's a Carver Cascade 2, runs off gas or 240V electric (where available) and will go here:
Needs to be raised up a bit to clear the top of the sill, because it goes in from the outside. Had to pull off one of the plastic trim panels from the outside, which it turned out had been stuck on with goop rather than using the proper clips:
Nice. Cleaned everything up and marked out:
More holesaw/jigsaw action, although this one needed finishing by hand with a hacksaw blade on account of my last jigsaw blade snapping just after the shops had shut:
Strip the tape off and tidy the edges:
The eagle-eyed will have noticed that this hole's behind where the plastic panel goes, so a hole had to be made in that too. Because the heater has a flange on the outside that the mounting screws go through, I had to pack out the back of the panel so it didn't get all squashed and misshapen as the screws were done up. Rummaged out some bits of PVC and stuck them on:
Put the panel back on, slide the heater in and it looks like this:
I'd like to claim that the extremely close fit between the bottom corner of the heater flange and the wheelarch bulge was deliberate, but really it was firmly in the "happy coincidence/thank **** for that" camp.
Pop the cover back on and that side of the van now looks like this:
Like the toilet hatch, the flue cover was originally grubby off-white, it had the same paint treatment. The other filler to the right of the water one near the front is for the LPG tank.
this is great. I like this more than telly. keep it coming
Great effort, I'm also in the best thread ever camp
